EGR & TBI
Old Feb 2, 2007 | 03:54 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
EGR & TBI
I'm building up a 350, and would like to stay with the TBI
induction/control system. All of the aftermarket performance
heads I've seen so far, none have the exhaust port on the
intake side. How important is this for normal operation?
Here in TX, we have sniffer inspections, but I don't know
HC & NO limits are. I'll be doing my own tuning/chip burning,
but is it possible to tune for inspections without EGR?
The idea of one chip for inspection, and another for the other
364 days is okay w/ me.
Old Feb 28, 2007 | 05:05 PM
SydwayzTA 86's Avatar
Car: 1986 Trans Am
Engine: 5.7L TPI
i dont know how it is over there, but here in Ca. a part of the emissions test involves a "visual test" which includes the egr. so basically, no egr, no pass
Old Feb 28, 2007 | 08:48 PM
racer J's Avatar
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
We have a visual test here in Texas as well. How thorough it is from place to place is another matter.
It's my understanding that some of these intakes can have the boss drilled out for EGR operation.
Old Feb 28, 2007 | 09:25 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
its worth lookin into, i've checked that out in the past with little succes
Old Mar 1, 2007 | 12:18 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
depending on how you build it, it may pass the tail pipe test without a working EGR valve.
you may also be able to pull a little timing in the chip to help keep NOx down.
also, it can depend on where you take it, there is a RPM range the emissions machine looks for, usually above about 1200 but below 2500 RPM. normally the higher RPM you can run during the test, the lower NOx is.
as far as the visual part of the inspection, the valve isn't checked to see if it works or not, just that it is there & hooked up & looks like it works.
Old Mar 4, 2007 | 06:51 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Ive never had much of a visual inspection here in Texas, not saying they dont, but not me....They never even raised my hood last time.
Old Mar 8, 2007 | 08:37 PM
And thanks for the insight on just how that happens.....
Old Mar 8, 2007 | 08:50 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
No problem funny guy................No, i meant on other cars.....
sailtexas186548
Feb 17, 2017 03:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Glowsock
Sep 11, 2015 11:09 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
