tbi issues
Old Feb 4, 2007 | 12:21 PM
89rs_camaro's Avatar
Car: 89 rs camaro
Engine: 5.0
Axle/Gears: gm 7.5, 4.11 gears
tbi issues
hey i bought a 89 rs camaro its a 5.0 with a 700r4 and the check engine light allways comes on and the code says
54- Shorted Mixture Control Solenoid circuit and/or
faulty ECM.
i changed the computer and no differences were is the mixture control solenoid? it does ping a little bit but other than that it runs like a top and has alot of power just sick of the light shining in my face
Old Feb 4, 2007 | 04:49 PM
Home Built's Avatar
According to the chevy thunder website, 54 is a low voltage fuel pump code.
http://chevythunder.com/fuel_pump_code_54.htm
maybe this will help.
Old Feb 4, 2007 | 05:58 PM
Car: 89 rs camaro
Engine: 5.0
the fuel pump is ok tho it allways starts fine
Old Feb 4, 2007 | 07:24 PM
golden's Avatar
Car: '89 Firebird
Engine: 305 TBI (LO3)
Axle/Gears: 10 bolts 2.73
Could be a loose fuel pump relay relay connection ...
Old Feb 4, 2007 | 09:34 PM
Car: 89 rs camaro
Engine: 5.0
could be and its just setting off the light throwing the code at me ill scope it out
Old Jun 11, 2007 | 11:07 PM
Car: 89 rs camaro
Engine: 5.0
Re: tbi issues
ok a little bit of a long responce but it still comes on it bogs right before it comes on or if you bog it ill check the code tommorow
MustangBeater20
Oct 29, 2022 09:20 PM
Dwayne614
Sep 28, 2015 08:33 AM
z28addict8490
Sep 5, 2015 03:56 PM
db057
Sep 4, 2015 07:57 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
