TBI Spacer
Old Apr 9, 2001 | 12:17 AM
TMoNeE's Avatar
Car: 87 Z28
TBI Spacer
Thinking about getting a 1/2" tbi spacer.. what does everything think about TB spacers.. worth it or no. What does it do for you.
89 RS 305 TBI
Edelbrock 14x3 OE intake, Hypertech Chip, Street & Strip shift kit, flowmaster exhaust w/ high flow catco cat.
Soon: 3.73 gears, posi, Edelbrock TES headers(jet-hot) [I have them all now, just cant afford to get them installed]
AIM:TiMoThY9801
Stereo:
JVC Detachable face cd player w/ 2 Pioneer 12" subs in custom box, powered by Lanzar 600 watt amp.
Old Apr 9, 2001 | 09:06 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
changes some aspects of air coming into your engine like velocity, and turbulance and other things like increasing your plenum volume. Usually the changes are slight, but it can help with fuel atomization which can increase power, and it will change your powerband slightly. They are used for fine-tuning an already well tuned engine, which an l03 is not. But neverless, they have been used, and do improve performance. I would guess about as much as "power pulleys."
and remember, all engines/cars are different, even if we call them the same names. only way to know for sure if its good for you or not is to try it. Then you should tell everybody what you think.
Old Apr 9, 2001 | 12:36 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Sounds like you have enough mods to make a difference. Your throttle response should be a little better and you should have a little more torque. Not much but every little bit helps. I put mine on with an open air element. I think most of my power increase was do to the element but I am sure the spacr helped to
1990 RS 305 TBI T-5
.5" turbocity spacer
Summit 14X3 OpenElement W/k&N
Custom Exhaust
MSD - Wires, Cap, Rotor, Coil
Bosch Platinum +4 plugs
Metallic Red w/26,000 miles
S10K20
Oct 7, 2015 06:45 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Glowsock
Sep 11, 2015 11:09 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
