Edel. Performer TBI, use TBI spacer or not?
Old Apr 3, 2001 | 09:58 PM
Zar's Avatar
Zar
Should I use my TBI spacer with my Edelbrock Performer TBI Manifold? Thanks!
Old Apr 3, 2001 | 10:07 PM
steve8586iroc's Avatar
Try it both ways then you can tell us if you gained any improvement. It should be an easy test and we all would like to see the results.
Steve
Old Apr 3, 2001 | 11:19 PM
Zar's Avatar
Zar
Well I guess I will try that tomorrow.
Old Apr 4, 2001 | 08:19 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i plan to put on on when it gets warmer. ive got a 1 inch aluminum. youll prob feel a bit more launching power.
91 camaro RS
- 305 TBI
Mods: Performer tbi intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo, accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edolbrock springs, KYB struts and shocks
Soon to come . Posi 323 rear end , aftermarket LCA,s and panhard bar , Ascd ram air hood, Z28 spoiler and grille , white guage faces.
Old Apr 4, 2001 | 11:36 AM
Zar's Avatar
Zar
Well I took the spacer off. The throttle is a little bit better. other wise no difference. My engine still seems slower than when I had the old intake on.
Old Apr 4, 2001 | 11:39 AM
FastBroker's Avatar
That intake is no good, as I have been preaching... Get carb Performer Intake with adapter plate.
Old Apr 4, 2001 | 01:18 PM
pete92rs's Avatar
Zar, what other mods have you done? I am asking this because you should have gotten a gain from the intake swap. When I instlled the Edelbrock tbi manifold I droped .25 in the 1/4 mile and gained 3mph in the traps.
As far as the spacer goes, give it a try just be sure you have the hood clearence, remember
the new intake is a bit taller that stock and when you add one inch to that and it will be close.
Good luck!
Old Apr 4, 2001 | 02:30 PM
bbtaz97's Avatar
Car: 91 RS
i will say with the stock air cleaner housing and a spacer and the edelbrock intake although im not going to try, i dont think it would clear the stock RS hood. you might have to go to a low profile open air if you still have the RS hood
91 camaro RS
- 305 TBI
Old Apr 4, 2001 | 04:48 PM
Zar's Avatar
Zar
Well I have headers, highflow exhaust, open air element. Soon I will have highflow cat. I noticed when I drive it normal there is a hissing sound that apears. Kinda like extra air being sucked in. Any Ideas?
Old Apr 4, 2001 | 06:49 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
have you checked for vacuum leaks?
Old Apr 4, 2001 | 11:04 PM
Zar's Avatar
Zar
Im going to try to find where there is one. IF there is one. Im not quite sure how to though.
Old Apr 6, 2001 | 02:36 PM
Zar's Avatar
Zar
ok, well I check everywhere for a vacume leak and didnt find one. After checking around some more I narrowed it down to the fuel inj. I replaced the passenger side and my idleing problem went away and the car drive noticably better. I still have the bogging problem when accelerating normaly, dont know why. Im going to replace the other fuel inj. too and see what happens.
Old Apr 7, 2001 | 02:22 PM
NJ SPEEDER's Avatar
<font face="Verdana, Arial" size="2">Originally posted by FastBroker:
That intake is no good, as I have been preaching... Get carb Performer Intake with adapter plate.</font>
that's pretty funny. it is the same manifold if you look at the cross section. it just has a different mounting flange. besides it is a great manifold as my times seem to prove.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Apr 7, 2001 | 09:24 PM
FastBroker's Avatar
I agree that the manifold is better than stock, but a Performer with Adapter plate will outperform. DOn't ask me how I know. I cannot tell...
I think the hissing noise that guy is hearing is normal IAC air rushing noise... I hear it too. I get like 90ish IAC counts when cruising on the highway. Wassup w/that? Posted a while back about trying to reduce it by PROM work but runs so good that I guess I can live with it. Plus, any air going into the IAC will only increase the overall cfm rating of the 1-11/16" unit, which can't be bad, eh?
Old Apr 7, 2001 | 10:45 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
fastBroker,
What performer intake are you talking about. I have changed my mind about the TBI intake and want a performer one with the adapter. I am not sure hwich one to get though. Which one does everyone keep talking about. Also how much does it cost to have someone install such an intake. On average...I know I have to call around
1990 RS 305 TBI T-5
.5" turbocity spacer
Summit 14X3 OpenElement W/k&N
Custom Exhaust
MSD - Wires, Cap, Rotor, Coil
Bosch Platinum +4 plugs
Metallic Red w/26,000 miles
Old Apr 8, 2001 | 08:48 PM
FastBroker's Avatar
I am talking about the "for-carburetor" Edelbrock Performer manifolds P/N 2101 (no EGR) and 3701 (w/EGR) and using an Aluminum adapter plate, which Holley makes, for instance. Of course, you could really use any dual-plane manifold, like an Edelbrock RPM (350+hp, 5500+rpm on a regular basis) manifold or Holley/Weiand, Offy, etc manifolds. Bottom line is that you need to put the TBI bores more towards the front of the plenum than near the middle or rear of the plenum, as the TBI dedicated manifolds do. Carb manifolds with adapters almost always accomplish this...
You'll have to call around for the installation times/fees.
Old Apr 8, 2001 | 11:57 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Thanks,
what Intake come swith egr? I will get the adapter plate but I need everyhting else to hook up.
1990 RS 305 TBI T-5
Custom Exhaust
Old Apr 10, 2001 | 09:34 PM
Zar's Avatar
Zar
Ok, if both tbi and carb. manifold will performe just about the same why bother getting the carb. one? Yes its cheaper but you will have to buy the adapter making it almost the same price. Thats why I bought the tbi performer. Oh, and its not any easier to install the carb. one.
92 Firebird
305TBI, Edl.Tbi Perf.Manifold, Full exhaust, air intake, 16" wheels, Tbi spacer
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
