Whistling sound coming from Throttle Body
Car: 88 IROC
Transmission: auto
I have a new problem now which is annoying and i can't seem to get rid of it. It is a constant whistling sound which seems like its coming right out of the injectors. I changed the injectors along w/ the FPR (swapped them from my 92 RS), tightened all the throttle body screws and bolts and fuel lines, and the problem is still there. When i put my finger over the injector to stop the fuel from flowing, the whistling sound gets louder, so that's why i think its fuel related, and not vacuum related. Any ideas of what it might be? Thanks
Pat Hirsz
www.iit.edu/~hirspat/MyPage2.htm
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, gutted kitty, March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears(open), Ultimate TBI Mods,AFPR,MSD(ignition,coil&wires),Edelbrock TBI Manifold, 195ltr/hr fuel pump,
Eibach springs with KYB's all around,
Harwood cowl hood, Z-28 wing, fresh paint(black)
120,000 miles, 5spd, T-tops,slp headers on its way
92 RS, 305TBI, auto, 3.08 gears, 180 thermo, glasspack (no muffler)
Pat Hirsz
88 305TBI
I had a problem very similar to this. My problem was that the gasket between the TBI and the intake was cracked. I replaced the gasket and the problem was solved. I don't know if this is the same problem. I found it by squirting soapy water around the area it's coming from. When the wistling stops, that's the area that it's coming from. I don't know if this will help or if you have already tried it, but it's my only advice.
1989 Camaro RS
No Mods Yet, many to come
Check out my web page:
http://members.tripod.com/89camarors
1989 Camaro RS
Car: 91 Red Sled
It's suposed to be loud. It's even louder whtn the IAC turns on.
, Jon (350 TBI! getting 23mpg highway)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)AIM: JPrevost
- Holley 670 TB unit w/ 1/2" spacer/adapter
- Edelbrock RPM vortec intake
- 350ho 330hp vortec crate motor
- 8" harm. balancer
- Stewart stage 2 water pump w/160 thermo
- SLP tri-y headers to full 3"
- Rebuilt trans w/ SLP shift kit
- Centerline 16x8's all around
- 36/24 mm sway bars
- Full poly bushings, even motor mounts
- SLP LCA and panhard
- Alston SFCs
- Edelbrock 3 point STB
- Global west steering brace aka wonderbar
- Eibach pro kit springs
- Bilstien high perf. struts and shocks
- All this and I still have AC
Engine: turbocharged 4 cyl Dohc
Transmission: 5 spd sentronic
i noticed that strange whisling sound once i installed the K&N open element i think its the throddle body taking in more air that you may have not heard it when you had the snorkel set-up on the engine i never noticed it until i put the k&n on ... it's the K&N filter allowing more air to get to the engine the snorkel was more restrictive and it may have been quieter.....
91 firebird vert
tan top&interior
305/700r4
MY SITE HERE
[This message has been edited by GiddyUP305 (edited April 12, 2001).]
91 firebird vert
tan top&interior
305/700r4
MY SITE HERE
Terrell351
Jun 13, 2021 01:13 PM
Fast355
Dec 2, 2016 06:33 PM
