Big cam and big TBI
Old Apr 21, 2001 | 08:00 AM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
Big cam and big TBI
OK, let's say I have a cam with a duration of 236/242 (non advertised, this is at 1.5). And lets say I need to keep it TBI'd. I'll be using a TBI larger then a 2" bore on a single plane manifold, on an engine bigger then a 350. Is it possiable to burn a chip to run this setup good? I know it's alot of tuning, but is it possiable?
Old Apr 21, 2001 | 03:01 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Its possible to do anything when it comes to programming the GMECM. You can go crazy with it, once you get deep into it , changing code and whatnot you can pretty much adjust for anything
Old Apr 21, 2001 | 05:04 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
That's exactly what I wanted to hear, thanks Pablo!
1992 RS
305 TBI, Edelbrock Performer TBI, TPI heads, Open K&N filter, SLP 1 5/8" headers, !cat, custom 3" exhaust, Flowmaster 80 series, MSD 6-AL, MSD Blaster GM coil, Accel Cap and Rotor, Accell 8.8 MM wires, World Class T-5, B&M Ripper Shifter, Nitto 275/50/15 Drag Radials, Radial T/A's up front, LakeWood LCA's, Edelbrock panhard rod, Aluminum driveshaft, LakeWood Drag shocks, IROC rear springs, custom interior, etc.
junkcltr
Aug 2, 2019 11:12 PM
lt1z350
Aug 28, 2015 05:57 AM
bdads
Aug 24, 2015 06:01 PM
cstrobel65
Aug 15, 2015 10:19 AM
