Stalling problems
Old May 21, 2001 | 01:56 PM
92rsconvertable's Avatar
Stalling problems
i have stalling problems when i am at red lights and the engine is hot. I have a 92 rs TBI. I was told it might be the vacum hose, or maybe the EGR. If anybody has an idea to what it might be, or knows how to fix it let me know.
Old May 21, 2001 | 02:47 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Is your computer throwing any codes?? A little more info would be helpful also. Maybe try cleaning the IAC and the other basic stuff. Search the archives. Questions like these are posted almost once a week at least. Goodluck
Old May 22, 2001 | 12:44 AM
thank you.. i really dont know any other information about it.. all i know is it happend in my old camaro and its happening in this one. i tried checking the EGR there doesnt seem anything wrong with it, and i checked the vacum hoses they all seem alright. ive tried taking it into the shop to get it fixed and everytime i do they say it doesnt happen to them.
Old May 22, 2001 | 05:37 PM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
Is your car running rough at idle? If so, I would tell you to check the vacuum hoses at the MAP sensor. I had a leak, and it ran like **** at idle, and would stall out all the time.
Godti
'89 Trans Am (Red)
305 TBI 5spd
Old May 22, 2001 | 10:33 PM
The car runs fine otherwise. its just when i have to stop at a red light the car stalls out.
Old May 22, 2001 | 10:54 PM
Snowdog 91 Formula's Avatar
My friend Jeff has a Pontiac Sunbird that had the same problem. He had to get a throttle position sensor and that fixed it right away! He tried everything else, even taking it to a mechanic, and the mechanic didn't even find it! There were NO codes being thrown from the computer either!
Amazing. I hope this helps you out!
-Snowdog
Old May 23, 2001 | 10:33 AM
thanks ill try that out.
Old May 23, 2001 | 10:56 AM
FastBroker's Avatar
Don't try that until you check your codes. Could be a waste of scratch.
Old May 23, 2001 | 11:16 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Also check your fuel pressure UNDER THE EXACT SAME CONDITIONS. You could have a faulty fuel pump
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
