LT1 CAM VS LT4 CAM
Old May 26, 2001 | 11:40 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
LT1 CAM VS LT4 CAM
WITHC ONE WOULD BE GOOD TO DROP IN A 305 TBI. I HAVE A HIGHER STALL CONVERTER ALREADY AND I WANT TO KEEP IT EMMISIONS LEAGAL BUT AM GONNA DITCH THIS STOCK CAM SOON AND B/C I KNOW A CAN FIND BOTH OF THESE USED AND IN GOOD SHAPE , IM DOWN TO THESE 2 CHOICES. I ALSO DRIVE THIS CAR EVERYDAY AS WELL. ONE LAST QUESTION IS HOW MUCH OF A GAIN WOULD I SEE FROM INSTALLING EACH??
THANKS
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler, white guage faces, megashifter..
next month: spohn LCA's and panhard rod, BMR relocation brackets, 323 gear
Old May 26, 2001 | 03:28 PM
NJ SPEEDER's Avatar
the gains from both would be almost the same if you can find a 96-97 (285hp) LT1 cam. the prob with the extra lift on the LT4 cam is that it will put the valves almost intothe bore. this will mess with the airflow around the valve and the extra lift will get lost as turbulence interferes with proper air flow. you would get a touch more power from the LT4 cam, but i don't think the couple hp would be justified by the extra expense that you are likely to pay for it.
if the rest of your set up can handle all the new flow, ie: good heads and intake, you could gain anywhere from 25-50hp once it is all tuned in.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old May 27, 2001 | 05:01 PM
Vader's Avatar
Ask New87. He put a used-but-nice LT1 cam in his 305 TPI with only an AFPR and dropped almost a second from his times.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
