LU5 CROSSFIRE HELP
Old Feb 26, 2007 | 09:43 PM
3rdgenparts's Avatar
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
LU5 CROSSFIRE HELP
Ok I normally don't do this but I need expert help.
My 305 LU5 crossfire is acting up(no surprise )
Problem:Erratic idle
No codes are showing
Black smoke at times(running rich I guess ?)
Rpms good when cold but after it warms it goes down and wants and does die out.
Idle fluctuates up and down
My guesses is a throttle position sensor,Timing,Bad injector.I already did a ALL GM tune up last October T45 plugs,wires,cap,rotor,dist.
Any constructive input would be appreciated
Dave
Old Feb 26, 2007 | 09:54 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Sounds like bad injector...
Old Feb 26, 2007 | 10:24 PM
Home Built's Avatar
Temp sensor.. maybe..
that'll make it run rich if it is telling the computer that it's colder then it is.
Old Feb 27, 2007 | 07:39 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
The throttle shaft bushings could be worn.That could cause all the problems you've listed but won't cause the SES to come on.You may want to join,if you haven't already,the Crossfire Injection Vault( http://www.crossfire.homeip.net ).There is a lot of good info,and good people as I'm learning,to be found there for the crossfire setup.Most there have '82 or '84 CFI Vettes but the same principals apply to our LU5's.
Old Feb 27, 2007 | 10:05 AM
Ronny's Avatar
test the TPS. hook up a VM and move throttle. should show smooth succession of voltage readings.
look at the injecctor as it fires. should be nice conical spray no drips.
temp sensor possible as well.
i would check for codes anyway. might still have a code hiding. most auto parts stores do for free.
how old is 02 sensor? i think the scan tool will show its functionality as well.
Old Feb 27, 2007 | 11:20 AM
On Probation
Thanks guys
I think its one of the injectors.The rear one is not spraying in-sync with the front one.Acting like a clogged shower head spraying fuel everywhere.BUT it has flashed for a tps sensor before but just disappeared after time.Temp sensor ??
02 sensor is new Bosh installed with the tune up last October.
Old Mar 4, 2007 | 05:35 PM
On Probation
Replaced the throttle position sensor,But no luck I guess its time to rebuild the throttle bodies. Thank G*d its only around 100 bucks for both
Old Mar 5, 2007 | 09:31 AM
Ronny's Avatar
i would check with Dan(Lions Den) at crossfire forum on the rebush.
Old Mar 5, 2007 | 10:52 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Try applying/spraying a thick oil onto the exterior ends of each throttle shaft bushing (where the shaft inserts into the TBI body). If the idle fluctuation goes away for a brief period of time (while the oil prevents the vacuum leak), then it would confirm that you need the a bushing installation for each throttle shaft.
Try it first before you take the plunge.
Old Mar 6, 2007 | 09:56 AM
djr_678's Avatar
Car: 98 T/A 94 dodge ram
Engine: LS1/ 5.9
I had 83 crossfire did the same thing after going over it couldn't find anything when i finally went to swap to a carbed setup and rebuild the 305 I found the IAC valve loose apparently and was sucking air, when i pulled the heads the exhaust valves were white from running so lean
Old Mar 8, 2007 | 08:03 PM
On Probation
Thanks,But Where are they located ?? I couldn't find a illustration in my '82 service manual.Or if its in there what page ??
Old Mar 9, 2007 | 07:22 AM
kdrolt's Avatar
Engine: LO3, LO5
The throttle shaft bushings are the circular holes that the throttle shaft rides within. I think you should be able to find the 2 locations (per throttle body) where the throttle shaft enters the TBI body.
Old Mar 11, 2007 | 08:26 PM
ben73's Avatar
You MUST check the temp sensor in the front of the manifold.
It will, and often causes the symptoms you are describing?
Old Mar 11, 2007 | 11:06 PM
On Probation
I guess it wouldn't hurt.They only cost $8-10.
PurelyPMD
May 5, 2016 04:57 PM
NZKnight
Oct 15, 2015 02:47 PM
Tweeks25
Sep 17, 2015 08:04 AM
edoff13
Sep 11, 2015 03:55 AM
