WOuld L98 heads work well on our LO3 engines?
Old Jun 20, 2001 | 03:07 PM
Mike-88CamaroTBI's Avatar
I have picked up a decent l98 cam for my car.
I can also pick up a pair of L98 heads in good running shape for $100 shipped. They have larger valves than our heads. I am referring to the cast iron heads not the aluminum ones. The heads are 64 cc chambers with 72o center bolt hole angles. I was considering milling them down to 55cc or so. Is this doable?
Alternative idea is to pick them up and get them ready along with a 350 short block with
non roller cam and a deep breahing state of tune and then telling my wife that I have to replace the engine to fix my leaky at startup valve seals.
mike
1988 Camaro Sport Coupe305TBI-4spdAOD-2.73open in "bought stock" condition. That'll change if it stays around here much longer mike.davis@firstunion.com
Old Jun 21, 2001 | 08:03 AM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Yeah you can make them work, I use the vortech heads and they come with the same size chambers. I know they are not the best flowing heads but I think if you get them milled they will help.
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Jun 21, 2001 | 11:54 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you mill them down that much, wont you have problems getting them to bolt to the intake?
Try to find some 305 TPI heads. Or better yet, put the money towards a roller 350 block.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Azrael91966669
25
Jun 20, 2017 04:04 AM
CRFred
Feb 7, 2016 11:39 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
matthew911
Aug 12, 2015 09:38 AM
