Order game
Old Jun 21, 2001 | 12:14 PM
92Camaro305TBI's Avatar
Order game
In what order would be the most effective? Smartest to do in order?
Cam
heads
eprom
open element
rims
tires
headers
TBI unit
fuel pump
seats
replacment hood
spark plugs
plug wires
ANY other suggestions? Thanks guys.. And dont make me feel dumb.. we all have to learn at one time
92 Camaro 305 TBI Automatic. 2.5 high flow cat and 2.5 pipes into3.5in tip, shift kit. Tinted windows(legal)...
Future mods. Spark plug wires and plugs, Headers, O.E., any other advise on getting to 300+ HP would be appreciated. Thanks
System = Sony explode CD/MD receiver, Rockford 6x9 Fanatics, 4x6 Clarion in the front, 2 12" Hx2's(Rockford) in custom box(black carpet) 1 farad cap, 800x2= 932 total watts Rockford Amp 4gauge wire kit.
Old Jun 21, 2001 | 12:44 PM
NJ SPEEDER's Avatar
prolly do the exhaust, then the suspension/chassis(tires, torque arm.....), then fuel pump, head/cam/intake all together if possible, then get a custom prom done to match the new combo.
if you go in this order the rest of the car will be ready for the power of the new engine.
hope this helps.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Jun 21, 2001 | 01:39 PM
Now that you mention it... I haven't really been messing with the suspention.. If you could fill me in.. You mean like sway bars and Such... I was always under the impression that we had really good suspentions.. what all needs to be upgraded? thx
Old Jun 21, 2001 | 01:55 PM
Tas's Avatar
Tas
In order of practicality:
open element
spark plugs
plug wires
cowl hood
catback
3" cat and headers
gears
Lower control arms= LCAs
intake
heads and cam
eprom
tires
'92 RS's have awesome rims and tires. why mess with them?? just get some bigger drag radials in back. go for the sleeper look
Most effective order of buildup:
Open element
cam
heads and headers
(Putting stock exaust manifolds on new heads is a waste of time and energy. If you pull the heads make sure to put headers on too.)
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Jun 21, 2001 | 03:46 PM
Cool thanks.. dont need a catback though... question on the OE... I was looking at the current intake setup... where the air comes in before it reaches the filter theres a tube in the path or whatever its called... when putting on an Open element.. I dont see a place for that.. what do you do with it?
Old Jun 21, 2001 | 03:56 PM
92fire-audio's Avatar
Are you talking about the metal tube that comes off of the exhaust manifold? If so, thats not really needed, actually that is only good if it is really cold outside. I think it is called a heat stove, what it does is it warms up the air before it goes into the engine so that the engine heats up faster. The problem is, when it's 100 degrees outside, who needs HOTTER air going into the intake? Thats just 1 of the many reasons to get an open element.
Old Jun 21, 2001 | 04:23 PM
Yeah thats what I was talking about .. just wasn't sure what it did... do I plug it up with something else.. or just take it off and have a hole in the exhaust manifold? Thanks
Old Jun 21, 2001 | 05:15 PM
4-bolt's Avatar
It's not actually a hole in the exhaust manifold. It is a whole in the heat shield of the exhaust manifold. Start with little stuff and work your way up. Things that are in the same area do together to save money and time.
open element
plugs and wires
-heads
-cam
-intake
-throttle body
-headers
--Do all these at the same time. You will save money on gaskets and labor if you pay to have it done.
'87 Silverado
350 4 bolt main bore .040 over
TB Injected
Ported and Polished heads
Comp cams 268h cam and top end
Flowtech headers
3.73s on Detroit locker
Old Jun 21, 2001 | 05:31 PM
thanks guys...
Fireslash
Apr 11, 2016 06:43 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
jaridjohn
Oct 5, 2015 07:01 AM
Bigold4x4
Sep 28, 2015 05:21 PM
