My car keeps stalling... Embarrassing
Old Jun 23, 2001 | 11:35 PM
One Eyed Jack's Avatar
Okay yeha my car stalled in front of a big group of people today (see the FIRDAY post on THEORETICAL DRAG RACING board). My car stalled FOUR times today- TODAY ALONE. Heres what it feels like...
The car begins to lose RPMs and it sounds like the engine is hitting really really off. The car struggles to save itself, but sputters out and dies. Then it takes a few seconds to start it again, and will only start at WOT. And even then it inches up on the RPMs, releasing a huge cloud of black smoke. It usually takes an additional 10 seconds to start after it stalls.
Before I pay millions of dollars to have a mechanic guess and check what my problem is, what do you think is wrong?
Old Jun 24, 2001 | 12:16 AM
1989camarorsrs's Avatar
i had that problem 2 i just bought carbirator cleaner and sprayed the throttle body down and bought carb cleaner which u put in ure gas tank, it used to stall once or 2 times week hasnt done it since then about a month ago
Old Jun 24, 2001 | 01:13 AM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Well, if it's not throwing any codes just check and recheck all your sensors and replace any that you have doubts about. Most of them won't run you too much and you should be able to change them yourself without too much trouble.
Old Jun 24, 2001 | 01:19 PM
yeah I thought it was probably an oxygen sensor.
Old Jun 24, 2001 | 04:03 PM
EVILFACE's Avatar
Check the fuel pressure. Mine was acting a bit like yours and turned out to be the fuel pump. It was only putting out 4 pounds which it should be around 13.
Evil's 88 Camaro
Stock 305 TBI Auto, Flowmaster, Full 3" Exhaust, B&M Megashifter, K&N Open Element, MAC Lower Control Arms and Panhard bar
Old Jun 24, 2001 | 09:34 PM
where can i check it at?
Old Jun 30, 2001 | 02:07 AM
Motopsyco's Avatar
Car: 89 firebird, 03 Avalanche z71
Engine: 5.0 stock (for now)
Transmission: 700R4 auto
Axle/Gears: stock 2.73 for now
i have had 2 similar probs on my t/a one was the throttle position sensor (TPS) went bad kept stalling & flooding itself out a quick fix when it happens (if that is the prob) just to get you buy is to unhook the fuel injectors, just the wire plug (mine was tbi, and i dont know if yours is) and crank it til she starts, the plug it back in
Old Jun 30, 2001 | 07:45 AM
El Guapo's Avatar
Take camarorsrs's advice. Clean your throttle body. Carb cleaner works just fine. You may also want to remove and clean your Idle Air Controll solenoid. On a MPFI or TPI setup it will be the thing sticking up to the top left of your TB. Just unscrew it, hose it off, then, hose the air passage off also. Do it w/ carb cleaner, mind you.
Clayton
Old Jun 30, 2001 | 06:29 PM
I just had my injectors cleaned a few months ago. The car stalled before then too.
Old Jul 3, 2001 | 07:34 PM
Eddie's Avatar
Try the temp sensor, just fixed the same problem on a peice of crap ford(mercury sable). It wouldn't start if warm unless you floored it and the it had hesitation in the throttle and black smoke. My car,89rs305, has had the same problem since I got it 11 years ago buy that sensor has been changed so I am currently in the process of narrowing it down. It only happens to my car about once every 2 months and I have no black smoke so check that sensor thing I told you about.
Old Jul 3, 2001 | 08:57 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
My car was doing the same thing when i accidently broke the temp sensor when changing the manifold. The connection was still on it, but very loose. I taped the connection and no more problems.
Pat Hirsz
www.iit.edu/~hirspat/MyPage2.htm
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, no cat,SLP 1 5/8" headers and y-pipe March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears(open), Ultimate TBI Mods,AFPR,MSD(ignition,coil&wires),Edelbrock TBI Manifold, 190ltr/hr fuel pump,
Eibach springs with KYB's all around,
Harwood cowl hood, Z-28 wing, fresh paint(black)
120,000 miles, 5spd, T-tops
0-60mph-7.2s-Gteched
92 RS, 305TBI, auto, 3.08 gears, 180 thermo, glasspack (no muffler)
Old Jul 3, 2001 | 09:06 PM
colincamaro's Avatar
had the same problem, it was my pick up coil
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
