TBI "sticks" when throttle closed.
Old Jul 5, 2001 | 03:38 PM
Chuck's Avatar
It's not the cables.
Any ideas and fixes??
Thanks!
Chuck
Old Jul 5, 2001 | 04:44 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Mine was sticking at one time because the idle set screw backed out just enough to where the butterflies closed tighter and jammed up a little in the bores,cause the butterflies are just a hair elongated.I had to drill out the cap that covered the screw and turn it in a bout one turn and that solved the problem.
'91 RS 5.0 TBI
New paint-solid black
ROH Snyper wheels-17x9 wrapped in 275/40/17
Eibach sportline springs
ASCD SS hood, High-rise Z-28 spoiler,
Hooker super comp headers,dual 3" exhaust,two 1-chamber Flomasters,Iroc sway bars,wonderbar,140 Iroc gauge cluster,Iroc steering box,Auto meter gauges,dual guage A-piller pods,open air filter,AFPR,smog delete
TBI mods,180* thermostat,
383 stroker in the works
President-Austin 3rd Gen F-body c.c.
Austin 3rd Gen F-body c.c. message board at
www.hpsmotorsports.net
See my car and others at www.ride4life.net
Old Jul 5, 2001 | 05:15 PM
NJ SPEEDER's Avatar
that is the most likely cause. it is also a good idea for all of us to spray a little bit of pentrating lube into the throttle shaft area. the soft aluminum of the body rubbing the steel shaft can cause a bit of distortion over time. keeping it slippery is the best defense.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Jul 5, 2001 | 06:14 PM
ChevelleCLM's Avatar
These guys are right on the $$ tighten up your idle adjustment until it stops sticking.
69 Chevelle 2dr hardtop blue, bench seats, 12 bolt w/3.73's muncie 4 speed. best 14.5@90
92camaroJoe
Jul 29, 2023 07:57 PM
pimp2303
Jul 27, 2017 02:03 PM
92camaroJoe
Aug 13, 2015 06:07 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
