TBI MOD QUESTION
Old Jul 3, 2001 | 06:01 PM
JeffC1500TBI's Avatar
TBI MOD QUESTION
OK HERE IS A LINK TO THE PIC...
www3.sympatico.ca/r_martel/tbi.jpg
ok the above img is a pic of a spare tbi unit I had bought for parts.. I wish I could mod that one but there 's an extra vaccum line connection and the others aren't the same size for some reason.. this is why I want to make sure I mod my good one properly.
do I grind just #1 flush or do I also grind #2 ??? #2 seems to have fuel that hits it. If I remove it won't fuel spill out of the tb?
also to grind it do I use a dremel?? if so what kind of bit would be best for this??
thks AGAIN..
'88 C1500 350 TBI
Belltech 2/4 Drop,
Nitro Drop Shocks,
3.73 Rear gear ratio,
Edelbrock performer TBI intake, performer cam, timing chain,
Hiflow cat with Rhino dual 2 1/2" out the rear.
[This message has been edited by JeffC1500TBI (edited July 04, 2001).]
Old Jul 3, 2001 | 06:07 PM
o
Old Jul 3, 2001 | 06:08 PM
firbird's Avatar
no pic
Old Jul 3, 2001 | 06:11 PM
ok then... photopoint are becoming real desp. for money I guess..
Here's a link to the photo..
http://albums.photopoint.com/j/View?...nce=0&res=high
thanks again
Old Jul 3, 2001 | 06:12 PM
ok I guess they are just reall A##es..
I'll post it when I find somewhere to host the pic..
Old Jul 4, 2001 | 07:24 AM
the link for the pic is up top
thanks..
Old Jul 4, 2001 | 07:57 AM
firbird's Avatar
you grind both of them down. the fuel should not come up that high it inless it has something wronge with the injector
Old Jul 4, 2001 | 07:59 AM
firbird's Avatar
oh yea welcome to the bored if you stick around you will learn a lot.
Old Jul 4, 2001 | 09:03 AM
scauffiel's Avatar
There's no reason to grind number 2 down - matter of fact depending on how you grind it down you may end up splattering fuel out of there. I'd leave that area alone. Radius the entire edge of the bore nicely, get rid of number 1's ridge and that's about all you're gonna get out of her.
Darth Steve
Steve's Trans Am Temple
Old Jul 4, 2001 | 11:54 AM
great ... thanks for all the help.. this is by far the best forum I've ever been on.
as for grinding... can I use the dremel and if so what kind of bit would be appropriate? should I use the cutting disc first and then smooth it out?
thks
Old Jul 5, 2001 | 06:28 PM
bigred305's Avatar
Well I wish I had known about that before I ground down where you are talking about #2 because the one on the TB I am working with is now gone, ohhh well. Anyway I used a high speed grinding wheel to get rid of the edge but the hig speed cutter would work on the dremel. Also to smooth down the radius some I used the sanding wheels. Does anyone think i will have problems since i removed those ridges?
87 C-10
305 TBI
(yeah I know its a truck, but you are the best TBI guys I have found)
Performance
**Somewhere around a 16.8 @ 85 ish (G-Tech)
*Freshly rebuilt 305 bored +0.030 over (311)
*K&N Airfilter
*Homemade Ramair w/ modified intake
*180 thermostat
*Custom True dual exhaust(Flowmaster 40's)No Cat's
*TD Performance TBI Spacer
*Mobil 1 10-w30
*Redline Water Wetter
**(alot more done, but I don't feel like boring everybody)
Old Jul 5, 2001 | 06:34 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
no, you wont have any problems, any gas that may splatter will eventaully evaporate and go into the engine. and it would be a minute amt unless like stated above, you had a problem with one of your injectors
Old Jul 6, 2001 | 05:57 AM
scauffiel's Avatar
Yeah, I guess I should have qualified/clarified that statement. With my injector tower spacer I can get fuel splash pretty good up fairly high along the inside of the bore. If you don't have that you probably won't have any problems at all.
DS
Old Jul 6, 2001 | 12:22 PM
JPrevost's Avatar
Car: 91 Red Sled
The injectors should be spraying just around the edge of the blades. If it's spraying above then you need a smaller spacer! The idea is that at light throttle position, the fuel will be atomized by the fast moving air around the blades.
, Jon (350 TBI!)
91 Red My website
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
dutch930
Sep 11, 2015 06:58 AM
PestilenceIV
Aug 20, 2015 02:33 AM
redmaroz
Aug 16, 2015 11:40 PM
