tbi to carb
tbi to carb
ive been pricing around and an edelbrock intake with like a double pumper carb will run me around the same price as a tbi manifold and bigger injectors, I should be able to pass emissions with a new engine using carb right?? When changing from tbi to carb i would just have to disconnect the computer right, Do you guys think i should go with the oldschool carb or stick with tbi? Thannxxxx
Car: 92 Camaro RS
Engine: 305 TBI
No way is a double pumper or any other carb. going to pass emissions, especially if they do a visual check on it, and your gas mileage will go to hell too.
92 Camaro RS 5.0 5-Speed(Quasar Blue)
14" Open Air Cleaner
3.08 Posi-trac
Edelbrock TBI Intake
Crane cam
Ported & polished stock heads 3 angle valve job
HyperTech Chip
SLP Headers (Ceramic Coated)
UltraFlo cat-back exhaust
74 Dodge Dart Sport 360 (11.2 1/4 mile)
2000 Dodge 1500 Ram Sport
3.08 Posi-trac
Crane cam
HyperTech Chip
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
changing to carb is not that easy .... first of all your distributer , transmission are both computer controlled. your fuel pump needs to be changed to aftermarket electrical or mechanical pump . your distributor needs to be changed to vacuum advance...and depending on what year tranny you have you need to see if it is computer controlled which it most likely is if you have a tbi. there are stand alone systems where you can hook up your tranny to if you have a carb though..i believe jet performance has them..dont quote me on that though im just going off my memory. another thing that might go..which im really not sure of though is your cluster panel..a few gauges might not work....if anyone knows more about this letme know i am very interested in this conversion...also i would like to know if you get a noticeable performance edge...thanks
Manolis are you Greek? I have a friend that's half Greek/Italian with the same name.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
yup im greek.... oh i forgot to mention my car in the profile thingy....here goes.....91 rs lo3 motor with hypertech thermomaster chip, 3.73 gears , high flow cat , two chamber flowmaster , nitrous works 125 shot , i just changed the timing chain last week put in a mellings chain with crank and cam sprockets, 160 thermostat , 160 fan switch , open element 4 inch k&n filter , 3 inch legendary cars fiberglass cowl induction hood . new urethane paint with three coats of clear . 245 front tires and 255 in rear. polyurethane
endlinks front and rear . new kyb shocks all around and new springs all around. no timeslips yet !!!!
Billy Decker
Sep 4, 2015 03:46 PM
I got 1 MP3 on my site you might like
