TBI Intake Manifold
Old Mar 19, 2007 | 01:47 PM
nomad88z's Avatar
TBI Intake Manifold
So i found this heads/cam kit made by trickflow for small blocks, and i found a high-flowing TBI unit through summit, but what i can't find is an intake manifold to match both of these parts. are the trickflow 23 heads the same angle as standard L98 heads? Who makes a performance TBI intake that would fit those heads?
thanks guys
Old Mar 19, 2007 | 06:00 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
A 23 degree head is the factory valve angle and requires no special intake. Where you get into trouble is with vortec, raised port or heads with a non stock valve angle. Your stock intake will probably bolt right up to those heads, but that would defeat the purpose. You can use any of the redily available TBI specific intakes out there, but you would be better off performance and money wise to go with a carb intake and an adapter plate to bolt your TBI to the intake. Keep in mind that you will have to do some fab work to get the throttle cables to work properly.
Hopefully you've done your homework and know that you will need to retune your ECM if you ever hope to make it out of the driveway with these mods. Mailorder won't cut it here, DIY is the ONLY way unless you want to spend a small fortune to have some one else dyno tune it.
Old Mar 19, 2007 | 08:30 PM
BHall71's Avatar
Car: 95 Silverado
Engine: TBI 350
Axle/Gears: 3.73 Detroit Truetrac
If your tuning your own chips I highly suggest trying to find a Weiand 7525 single plane intake with a TBI to 4 barrel adapter. I was running a Holley dual plane Projection TBI intake and picked up a 1/2 second in the quarter by switching to the Weiand single plane.
If your not doing your own tuning I would stick to a dual plane.
Brian
Old Mar 19, 2007 | 08:52 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Brian
Does anyone know if the Weiand 7547 is equivalant to the 7525? I have looked and looked but I cannot find a 7525.
Old Mar 19, 2007 | 09:13 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
7525 has been discontinued. I ran one for some time, it was overated. The Performer RPM pulled just as well all around as the 7525. The difference is the 7525 lagged on the bottem compared to the RPM and the 7525 had EGR provisions.
EDIT- I am a big fan of Dual Plane Manifolds with a 1" thick OPEN center spacer under the TBI. That is how I run ALL my TBI engines now.
Old Mar 19, 2007 | 10:29 PM
nomad88z's Avatar
thanks guys, i appreciate it
Old Apr 20, 2007 | 12:11 AM
blizzted's Avatar
Car: 2000 tahoe,94 ex-cab,92 rs
Engine: 350,350,305
Transmission: all autos
Re: TBI Intake Manifold
i have been trying to find some info on this i got some vortec heads for my new motor i have a tpi setup but im not gonna run it. the car came with a 305 tbi so i think im just gonna use a 350 bored tbi alot less hassle but should i use the vortec tbi intake or get a egr carb intake and adapter?
Old Apr 20, 2007 | 09:21 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The vortec TBI intake will be the most trouble free. The performance manifold will provide more performance, but will need addtional tuning. Both will require tuning regardless. Same with the TPI.
Old Apr 24, 2007 | 04:07 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Does anyone have any pics of where they did grind away in the center of the intake manifold, to match an open center spacer ? I know one has to weld up two coolant holes ?
Old Apr 24, 2007 | 06:43 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Wish I could run a DPM w/ adaptor in my upcoming project.... damn EGR requirement.
earlpote
Aug 28, 2015 10:42 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
