Timeslip
Old Mar 6, 2001 | 02:10 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Timeslip
60' 2.385
330' 6.363
1/8 9.679
mph 74.78
1000 12.489
1/4 14.880
MPH 93.66
80 some degrees
80 some % humidity
30 barometer
i only got 3 runs, this was the last one the first two i was still getting used to launching at the track and cut 2.7 60 foots
the car is down I estimate about 4 mph
not tooo terribly shabby considering ive done absolutely 0 time vs distance tuning, only plug reading
with a decent launch i think it could hit a 14.4 as it sits
Old Mar 6, 2001 | 09:23 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
91bird305, HERE IT IS.
Where is yours.
I should get the g-tech out and use it one of these days. Im just afraid it will read 17 or something.
Nice time.
Old Mar 6, 2001 | 09:51 AM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
Hey Pablo, can you list your mods here as well? I know that you have changed the cam and heads right? Something seems definitely wrong with your 60' times. I ran a 2.5s on my 60' with a 16.7s 1/4 mile. What kind of gears do you have? thanks
Pat Hirsz
www.iit.edu/~hirspat/MyPage2.htm
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, gutted kitty, March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears,
Eibach springs with KYB's all around,
Harwood cowl hood, Z-28 wing, fresh paint(black)
120,000 miles, 5spd, T-tops
Run a best of 16.7 @85mph before gears, slp headers on its way
92 RS, 305TBI, auto, 3.08 gears, 180 thermo, glasspack (no muffler)
Old Mar 6, 2001 | 10:42 AM
Tallboy's Avatar
im hoping to get the track soon
hopefully i'll crack into the 15's
came close to getting a 350
but fell through,I live in stupidville so im sure someone else will be trying to get rid of one cheap,gotta keep my eyes out for the vette heads too
congrats on the 14's
i knew it would happen
Old Mar 6, 2001 | 10:48 AM
cobrakiller1989's Avatar
Pablo, those are some pretty good times. Do you have any idea of how much total money you have into it? also, time invested and a list of mods? good job
Old Mar 6, 2001 | 11:28 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
mods
holley 670 tbi
edelbrock torker II manifold
214/224 sis cam
1.6 stamped rockers = .474/.498 lift
305 L69/Lg4 heads, #416 casting, stock valves, ported by me
stock injectors
NOS external regulator
edelbrock headers and catback
3.42 gears and power trax locker
T5
eprom programmer
probably some other stuff i missed
in total, engine mods probably cost me around 500 bux, but i have put considerable amounts of time into the heads (waste of my time) and prom tuning (for no reason, wasnt reading the plugs for months so that was wasting my time)
the 60 foot is bad because the car is hard to get off the line, either I spin badly, bog badly, or get somewhere inbetween and get massive wheelhop. I need some solid lca bushings and lca relocation brackets i think that will do the trick.
If i can get a g tech im sure i can get the 4 or 5 mph im missing, its all in the fine tuning. Im dissapointed with the time I was hoping for atleast a 14.4 and ideally a 14.2 as it stood.. i think the mph was good for a 14.4 but I needed more practice runs. The track was so packed though that I would get only one run like every hour and a half (this was on a wednesday!)
so you can see why i never go to the track, took me two hours to drive there, got three crappy runs, and then took me an hour and a half to get back. Burned 40 dollars in the process too to make it back on fumes.
Old Mar 6, 2001 | 12:44 PM
ONEFINE8T9's Avatar
i cant wait till eric sees this
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
Old Mar 6, 2001 | 12:51 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
lol its a slow *** et dood i was hoping for alot more.. ill get it just need some more fine tuning
Old Mar 6, 2001 | 01:20 PM
Pablo,
What were your shift points? Was it still making power? Was this with the 310? I dont think your times were all that bad for first runs. I wouldnt call them sh!tty.
Do you have AIM? whats your name?
Old Mar 6, 2001 | 02:34 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
my shift points were about 5800 rpm
i was crossing the line in third right around my shift point which was good. The motor does work out to a 310 but its probably down on power compared to a stock Lo3, the motor was free and obviously like a parts store rebuild. It has dished pistons which really hurts power. LO3s have flat tops
i go by TopfuelTBI on aim
and 11291690 on icq
i dont use aim as often but i can be reached on icq easy
ill turn on aim now
Old Mar 6, 2001 | 02:38 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
it was still making power, the car really pushes you back somewhere between 5000 and 5500... you can feel it start to run out of breath past that though but it will pull pretty hard to 6 and beyond though i dont normally ever do
ONEFINE8T9's Avatar
pablo may i ask y such a poor selection in heads? I think with a better set u might be able to improve ur times. I didnt see n e thing about a 3 angle valve job listed for the heads either. Are u running the stock clutch as well? The oem clutches for these cars arent all that good. I had to replace mine in my car and its only got 59000 on it. SO if u havent replaced it already i would recomend that over n e thing. Especially with a motor thats faster than stock.
Old Mar 6, 2001 | 02:49 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
the heads were way cheap, and they had a proper rebuild on them when i bought them so i couldnt complain
they arent that bad i think the car can hit 98 mph in the quarter which is pretty good however better heads would mean a world of difference
Old Mar 6, 2001 | 02:51 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
oh the clutch is a stock used one that i bought with the tranny.. it doesnt slip so thats not a problem
like i mentioned before, i think the dished pistons are holding me back substantially aswell, the car has no real quench area in the chambers
Old Mar 6, 2001 | 03:54 PM
ONEFINE8T9's Avatar
when u say dished pistons what do u mean, I know there are different types of piston tops but whats the difference and how do they affect performance?
Old Mar 6, 2001 | 04:44 PM
Mike-88CamaroTBI's Avatar
Hey Pablo. I had buh-buh-buh-buh-bad wheel hop. My rear tires were at 34 PSI (BF Goodwitch touring TA's). I dropped the pressure in 2lb increments. My magic number for ELIMINATING wheel-huh-huh-hop was 28lbs.
Mike
1988 Camaro Sport Coupe305TBI-4spdAOD-2.73open in "bought stock" condition. That'll change if it stays around here much longer
Old Mar 6, 2001 | 04:52 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
hehe mike i lowered my pressure too i was around 28... high pressure definately worsens the condition
Old Mar 6, 2001 | 05:55 PM
DM91RS's Avatar
Car: 91 RS
Nice to see your car running good! Get that wheel hop under control and it should improve with practice. I wish that you could try the vortec head with super victor that we talked about in the past! 13.9?
Old Mar 6, 2001 | 08:23 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
i would try that but ive re evaluated the situation and i feel that with dished pistons im just giving away way too much horsepower, i basically dont have any real quench area and dished pistions would not work well at all with a fast burn head
im just gonna go to a 350 next and use what ive learned on this little motor to make the 350 go
the 305 still has more left in it though
Old Mar 6, 2001 | 08:24 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
btw i think flat tops with vortecs, lt4 hot cam, and super victor would be way way way fast
Old Mar 7, 2001 | 12:22 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
LoL WOW! I need to start getting online more instead of studying.
Well Pablo...you finally did it. And I agree with you...I was expecting high to mid 13's with all the work u have put into that 310. But I think it might be a tuning thing like you said. Oh well, practice tuning it and tweaking it. You'll get a better time. Good luck.
What you guys thought I was gonna say something mean?
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Mar 7, 2001 | 09:00 AM
FastBroker's Avatar
Good job, Pablo. I think with a little chassis/hookup work, you'll get to 14-1/4.
A 350 will be easy for you because you have all the BIG flow TBI/manifold combo already, just need the longblock/shortblock!
Old Mar 7, 2001 | 11:26 AM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
Those pistons and heads are holding you back. You need a bigger cam, better heads, and flat top pistons to get 13's, but your making good times with what you got! You had wheel hop? time for some LCA's and a panhard, that'll take care of that.
With those temps, those are some real nice times.
Old Mar 7, 2001 | 04:34 PM
NJ SPEEDER's Avatar
hey pablo,
look for me on AIM sometime. i wanna talk to you about tbi and small motor theory.
AIM= TJM574
lata
tim
91 Camaro RS-LO3,Auto.
14.215@94.30 w/ 1.917 60'
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Jul 24, 2001 | 11:17 PM
chevyguy8's Avatar
Pablo, your a hero to TBI'ers.
My near dream is to get my 305TBI into the mid 14's, just like you and a few others have.
I dont know if you guys gotten the september issue of Chevy HI Perf. Im really following to see what they are going to squeeze out off that Lg4. Im also trying to do the same thing or about the same to mine. They are running 15.8's now and next issue they are getting some s/r torqs and a comp cam, shooting for 14's.
One last time, Congratulations!!
91 Camaro LO3 RS 5-spd
Open air element, 16in Chrm IROC-Z wheels, dual 30in chrm exhaust tips, Z-28 wing,ACCEL 8mm wires w/cap n rotor, K&N filter, flowmaster, headers in near future. dual fans.
Old Jul 25, 2001 | 07:00 PM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
Congradulations Pablo!
Old Jul 25, 2001 | 07:27 PM
scauffiel's Avatar
It may be a while gents before he sees this - he joined the Marine Corps several weeks ago and is going through boot...
Just wanted to let you know so you don't think he's blowing you off.
Steve
Steve's Trans Am Temple
86White_T/A305
Aug 17, 2015 12:16 AM
ontogenesis
Jan 27, 2003 03:57 PM
bhaas
Jul 6, 2002 04:13 PM
bhaas
33
Jun 15, 2002 08:06 PM
91RS5.7TBI
Apr 9, 2002 06:39 PM
