VSS Buffer update!
Old Jul 28, 2001 | 07:48 PM
PopaPork's Avatar
VSS Buffer update!
Just took out my dash cluster to see how complicated the VSS buffer is. Total job took me 1.5 hours. The hardest part of the job is gettin the Cluster off. Chiltons says just pull and I have read that in alot of posts. The fact of the matter is there is a clip on the speed cable, and no play in the length of the cable. You must jam your hand up there and wiggle it in and press on the clip while pulling like a crazy man. All of this will pop off the speed cable. To put it back on you have to hold it with one figer to keep it in the right place and with another finger push the clip in. PRESTO, it is off and on. Hope this helps some one down the road.
Pork
89 RS Camaro
Hedman Headers, Highflow Cat, Flowmaster 80 Series
180 Degree Thermo
Open Air Element with K&N Air Filter
Custum Burned Chip
So Many Mods......so little time
www.rit.edu/~cjp8408
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
tattmann
Sep 27, 2015 05:20 PM
