Will this cam change kit work for a 92 TBI?
Old Jul 30, 2001 | 04:31 PM
92fire-audio's Avatar
I'm gonna get a compucams camshaft and an Edelbrock TBI manifold soon, will this kit be all else that I need or will it even work?
It says its for an 80-85..
720-4406K
Old Jul 30, 2001 | 04:40 PM
NJ SPEEDER's Avatar
that sounds like a kit for a regular hydraulic flat tappet cam, our cars have hydraulic rollers in them.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Jul 30, 2001 | 06:51 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
You have to get the ones made for 87 and up, mine said it was for 87 to 89 I think and it worked fine on my 92.
92 Camaro RS 5.0 5-Speed (Quasar Blue)
T-Tops
14" Open Air Cleaner
3.08 Posi-trac
Edelbrock TBI Intake
Crane cam
Ported & polished stock heads 3 angle valve job
HyperTech Chip
SLP Headers (Ceramic Coated)
UltraFlo cat-back exhaust
74 Dodge Dart Sport 360 (11.2 1/4 mile)
2000 Dodge 1500 Ram Sport
Old Jul 30, 2001 | 07:01 PM
Do you happen to have the part number? I cannot find a cam change gasket kit anywhere on summit or jegs for anything newer than an 85..
Old Jul 30, 2001 | 07:09 PM
Also, I was planning on putting in a non roller camshaft. Do you have to replace a roller cam with a roller cam? The non roller one has lifters that come with it. IT's the 2020 instead of the 2020HR.. Both are crane compucams..
Old Jul 30, 2001 | 08:54 PM
FastBroker's Avatar
Keep the rollers. Get a roller cam. better stuff, more lift with lesser durations (good cams, anyhow) less friction, etc... I recc COMP roller XE cams (for EFI w/112/114 lobe sep, not 110!) with the lowest durations for everyday drivers, the bigger ones for draggers.
Old Aug 1, 2001 | 04:58 PM
Motopsyco's Avatar
Car: 89 firebird, 03 Avalanche z71
Engine: 5.0 stock (for now)
Transmission: 700R4 auto
Axle/Gears: stock 2.73 for now
speaking from a little recent experience in this matter, even if you want to change with a non roller cam, be sure to use a cam button (your 92 usues a retainer plate, wich a non-roller cam has no undercut for), because i put in a regular compucam in my 91, and the cam was nearly walking right out of the block. I replaced it with the 2031, and she runs beutifully, besides my computer wasnt reading the earlier model compucam anyways and would die at idle with the brake on
--Stormr
"If its in my way-It gets run over"
--'91 firebird
305 TBI
Hypertech chip-thermomaster
Edelbrock performer intake
Crane compucam 2031
B&M shift kit
straight pipe exhaust-with Flowtech resonator tips
160 thermostat
open element
MustangBeater20
Oct 29, 2022 09:20 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Terrell351
Jun 13, 2021 01:13 PM
camaro11j
Sep 19, 2018 08:49 AM
TreDeClaw
Aug 14, 2015 06:58 PM
