305 or 350 how do I tell???
Old Mar 29, 2007 | 04:56 PM
woodstock16's Avatar
Car: 1985
Engine: lg4
Axle/Gears: ????????
I own a 1985 camaro but cant tell what motor is in it a 305 or 350 i know they only came with 305 that year but i think it might have been switched any way of telling the diff without the number on body or block.the body vin says 305 and cant get to the block because of all the smog S#$T.please help i need to know
Old Mar 29, 2007 | 04:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 305 or 350 how do I tell???
There's no definitive way to tell without looking at the casting number, or measuring.
Old Mar 29, 2007 | 05:05 PM
Car: 1985
Engine: lg4
how do I measure
Old Mar 29, 2007 | 06:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Pull a head off and measure the bore.
Old Mar 29, 2007 | 06:22 PM
Car: 1985
Engine: lg4
how hard is that
what should each measure
Old Mar 29, 2007 | 06:47 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A 350 has a 4" bore, a 305 has a 3.736" bore from the factory.
It's hard enough that you would really rather just look at the casting numbers.
http://www.mortec.com/location.htm
Old Mar 29, 2007 | 09:28 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i am amused
also there is
nastyz28.com
look at these to help ID your engine:
http://www.nastyz28.com/sbchevy/sblock.html
http://www.nastyz28.com/chevy-engine-code-stampings.php
http://www.nastyz28.com/sbcmenu.html
Old Mar 29, 2007 | 10:05 PM
91V8Redbird's Avatar
Car: 91 V8 Firebird
Engine: LO3 305 TBI V8
What kind of fuel induction does it have (carb/tpi/tbi)?
Old Mar 29, 2007 | 10:13 PM
Car: 1985
Engine: lg4
eiter tbi or carb I know its not tpi
I have an o2 sencer if that helps(burned my self on it, lol)
Old Mar 29, 2007 | 10:33 PM
Car: 91 V8 Firebird
I had this same dilemma with an '84 z28 I bought, ended up being a 305 TBI from an 89 firebird. To tell if it's carb or TBI pull off the air cleaner assembly, and check for two holes with an injector pod over the top of them, if so, it is TBI, otherwise, if you see two or four holes, without an injector above each hole it's probably carb. This doesn't help me much, with whether it's a 305 or 350, though. Do the valve covers have ridges on the top or are they smooth, this should help tell if the motor is '87 or later(with ridges and 4 bolts through the center) or '86 and older (smooth valve covers and 2 bolts on each side of the valve cover)
Old Mar 29, 2007 | 11:13 PM
rsfromhell's Avatar
Car: 89 RS Camaro, 92 RS Camaro
Engine: 2.8 V6, 305 TBI
Transmission: Built 700R4, 700R4
Axle/Gears: 4.10 richmond, Stock
Well this could be just me but as far as i know in '85 all they offered were 305 V8's, the 350's were not introduced in the third gens until '87 and if my memory serves me right the 350's had tuned port injection. but if it is the original engine the easy way to find out what engine you have is to check the 8th VIN digit on your VIN number.
this web site is great for decoding VIN numbers, and RPO codes as well.
http://www.chevy-camaro.com/
the 8th digit should be one of the ones i listed below, they are the engine codes for '85. the codes next to the engine size is the corresponding RPO code for the engine as well.
hope this helps.
Falco
1985
2 151-88 (LQ9)
S 173-135 (LB8)
F 305-215 (LB9)
G 305-190 (L69)
H 305-155 (LG4)
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
