Too Rich
Old Aug 6, 2001 | 09:45 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Too Rich
My car is running rich. How do I lean it out without messing with the fuel pressure or stock programming. Can this even be done.
Old Aug 6, 2001 | 10:52 PM
My305camaro's Avatar
How do you know the car is running rich? The only real way to lean out the mixture besides changing the fuel pressure regulator setting, is to feed the car so much air that the the car needs the extra fuel b/c of the air. why don't you want to change the psi setting on the regulator? You might want to first look at what caused you to be running so rich if you haven't messed with the fuel pressure.
1991 Chevy Camaro RS TBI w/auto
Mods:
Edelbrock TES Headers, REALLY high flow cat, 2 1/2 in catback flowmaster, 160 stat, hypertech chip, MSD ignition (rotor, cap, superconduct. wires), Bosch quad4 plugs, Ram Air Box twin snorkel, all TBI mods, no smog stuff, no EGR, lots of suspention and alignment upgrades, and a big Chevy bowtie sticker on the back.
Fastest e.t.:
15.64 @ 87.8mph
Old Aug 7, 2001 | 10:45 AM
Well I did all of the ultimate tbi mods and then made my f/p regulater adjustable. Before I made it adjustable it ran good. i could never get the fuel pressure right with the adjustable regualtor so I just went out and got a new one. With the new one it runs rich. It will kinda flood itself if you let it idle for a few minutes. It has also lost some low end torque. I am not going to mess with my new fuel pressure regulator. Thanks
Old Aug 7, 2001 | 10:23 PM
steve8586iroc's Avatar
You may need to have your injectors cleaned. They might have some dirt in them causing one or both to not fully close thus causing it to run rich. So they may have been the problem, not your fpr, all along.
[This message has been edited by steve8586iroc (edited August 07, 2001).]
Old Aug 7, 2001 | 10:33 PM
Keith5's Avatar
Car: C1500
<font face="Verdana, Arial" size="2">Originally posted by brodyscamaro:
With the new one it runs rich. It will kinda flood itself if you let it idle for a few minutes.</font>
Sounds to me like the new one is messed up or something. The fuel pessure sounds too high. It ran fine before you messed with the regulator the first time?
Old Aug 7, 2001 | 10:36 PM
Correct before I messed with anything it ran fine. After the Ultimate TBI mods it ran fine. Then I ***** with the stock regualtor since then it is rich
Old Aug 7, 2001 | 10:40 PM
Keith5's Avatar
Car: C1500
Got a gauge on it? Did you take the injectors or the injector pod off? Maybe fuel is leaking from around one of them, it's worth a look, I'm sure you already have though.
Old Aug 7, 2001 | 10:42 PM
the whole TB has got a recent rebuild
antman89iroc
36
Jan 31, 2016 08:42 AM
Luigytico09
Oct 1, 2015 08:46 AM
James Sutton
Sep 23, 2015 02:18 PM
89fast5oh
Sep 8, 2015 09:55 AM
Jk_Under
Sep 8, 2015 08:13 AM
