lt1 cam question
Old Aug 7, 2001 | 03:24 PM
pimpintheRS's Avatar
lt1 cam question
i have a good deal coming thru on a lt1 cam.. he actually has like 3 of them one from a 94 and the others from 95-97 motors i was wondering which one i would want? one of them has a short dowel pin and the other a long one which would be easier to put in?are all the lt1 cams the same size? thanks
Shawn
Old Aug 7, 2001 | 05:24 PM
NJ SPEEDER's Avatar
the later cam, from teh 97, would be best. the early cam design has a split duration with matching lift on the intake and exhaust side. the later cam has the same duration deign but lift on the exhaust side is bumped from .450 to .460, for a little better breathing. on the stock LT1 it created 10hp more at the same rpm and a flatter torque band.
go for the 97 cam if the guy still has it. the dowel pin is not a big deal, if it is too long you can just grind it down.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Aug 9, 2001 | 04:32 PM
alright is this going to be worth it? will i actually feel it in normal driving and how much will it knock off my 1/4 mile times? stock heads and headers coming soon.. i probably wont put the cam in until i buy my manifold. is the cam worth it?
thanks
Shawn
Old Aug 9, 2001 | 07:20 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I read that it should give you about a half a second with the cam alone. I wish I had done the swap this summer as planned, but **** came up
Chuck Kulchar
1991 RS
Open Element w/K&N
3.42 - posi - disc
3" cat and Force II cat-back
Old Aug 9, 2001 | 09:02 PM
alright here are my plans 3.42's and posi with the new cam and an edelbrock manifold... the car is also lowered an inch and a half whatdo you think i will run? mid 15's? low 15's hopefully.. what are your times chuck? i am going to have same mods as you soon.. well i have a straight pipe.. yeah yeah emiisions so what i have 2 yrs.
Shawn
Old Aug 12, 2001 | 09:23 AM
Vader's Avatar
PimpRS,
There are about six different factory grinds for LT1 cams. Get the part numbers and check the specs before you buy. The part number is generally found behind the front journal.
Incidentally, the dowel makes no difference. The longer dowel can be driven deeper into the hole to the correct depth for a "standard" SBC timing set - you don't have to grind it off since the factory drilled the holes extra-deep.
Old Aug 12, 2001 | 01:37 PM
thanks for the advice.. what kind of improvement should i see with the cam and gears?
Shawn
Old Aug 14, 2001 | 01:04 AM
88 Camaro SC's Avatar
Car: 99 Trans Am
In theory, 1/2 sec with cam, 1/2 sec with gears and posi.
Nate
1988 Camaro Sport Coupe
  • Custom Interior
  • K&N Air Filter
  • Custom Ram Air
  • 180* Stat
  • Shift Improver Kit
Homepage: www.rsdragster.cz28.com
Old Aug 14, 2001 | 01:41 AM
good to know i got gears and posi sitting in my room and have a deal coming thru with a cam soon..
Shawn
midge54
Dec 27, 2019 04:14 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
Fronzizzle
Aug 9, 2015 01:15 PM
