T.B.I Spacer noise
T.B.I Spacer noise
I have a 93 chevy silverado Truck with a 305 TBI. I installed a throttle body spacer, and also at the same time I put a container of injecter cleaner in the gas tank. Now I hear this annoying buzz from inside the truck. But it is not noticable from the outside of the truck even with the hood open. I think it is the injectors. The guy at the auto parts store told me it is because of the throttle body spacer. He says it is because the sound of the injectors is bouncing off the inside of the intake. I was just wondering if anybody heard this noise and what it was.
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
It could be the injectors hissing, but it could also be a leak in the tbi spacer. try shooting some carb cleaner through the spacer seems and see if the engine bogs down. if it does you've got a vacuum leak there. I have heard injectors hiss, so it is possible to just be an echo.
good luck,
Mike
1989 RS.. 355, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job, 3 inch cat-back exhaust, 3 core radiator, 3.73 gearing with POSI.
good luck,
Mike
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I bet its just a hiss. I have a spacer and I can hear a hiss. I just had a vacuum leak repaired so I know its not that. But since I installed the Edelbrock intake I can hear a hiss in the car but not outside or under the hood. I would still check for a vacuum leak but if everything is bolted tight and the car (or truck) still runs smooth, I would not worry about it. You'll know when you have a vacuum leak.
1990 RS 305 TBI T-5
.5" turbocity spacer
Edelbrock TBI intake
180* stat
Summit 14X3 OpenElement W/k&N
Hooker 3" Areochamber
MSD - Wires, Cap, Rotor, Coil
Bosch Platinum +4 plugs
Metallic Red w/28,000 Pampered miles
(Still have the original wiper blades)
1990 RS 305 TBI T-5
180* stat
fahq clearly your name is vulgar and offensive to a prude. The decent folks who share an interest in TBI third gen. f-bodies, wish not to have such trailer-trash truck-driving profanity displayed on the board.
So change your gotdam mthrFAHQn Kogsugn FAHQggot a$s name now.
Sorry, I'm just so offended.
Thanq mr. snuffle-up-pigs-a$s ,That is what your name implies, is it not?
(j/k) no insults intended.
[This message has been edited by Formula9 (edited August 25, 2001).]
sjorgens
Oct 1, 2015 07:54 PM
