92 CAMARO tbi, clueless....
Old Sep 5, 2001 | 06:11 PM
Joey C's Avatar
I would like to do a few mods to my 92 305 TBI, 1st, i want flowmasters, people on this site told me 80 series are great, true?, I want straight pipes also and i do not know size, does anyone know what the outlet size will be from the flowmasters? is that was i need to base it on?, I want a 360 degree air cleaner to replace snorkel setup, there are two wires running intpo the current one, a vacuum line correct? and some other one. Is it possible to have the 360 open element air cleaner and do i need those lines or not?? any help is appreciated
Old Sep 5, 2001 | 06:42 PM
m3baller's Avatar
You can put an Open Element on your car, aka 360 air cleaner.
Read snuflupigus's tutorial here http://snflupigus.tripod.com/step1.htm
I'd also suggest going through the Ultimate TBI mods if you want some performance out of your car. just make sure you can tackle this, im not responsible for any mess-ups, don't kill the messenger.
https://www.thirdgen.org/newdesign/t...imatetbi.shtml
https://www.thirdgen.org/newdesign/t...matetbi2.shtml
My 1988 Firebird
91k miles, 305 TBI, auto, black exterior, red interior. GTS Blackouts.
Mods: Cherrybomb cat back with stainless steel tips, K+N filter.
Old Sep 5, 2001 | 09:48 PM
JPrevost's Avatar
Car: 91 Red Sled
I'm a little confused on what you're asking exactly about the exhaust. I personally don't like flowbastards because they really don't flow as well (or sound in my opinion) as good as all other free flow designs. If you want to go with flowmaster then call up Summit and they'll ask you for your car blah blah and the kit will be sent. If you already have exhaust work done like a larger cat converter or headers, then you'll need a 3" cat-back exhaust system and make sure you tell them that. I personally think the hooker system sounds a lot better than flowmaster, just my opinion. As for the open element (aka 360) air cleaner, Summit sells a $15 piece that includes everything. It's a drop base so you'll need to retain the stock spacer ring (it's imbetween your stock air cleaner and the engine).
About those vacuum lines and that sensor:
You can remove the sensor and simply zip tie it to anywhere on the firewall just as long as it doesn't touch anything hot! It's common to zip tie it to the MAP sensor. As for that vacuum line. Plug both lines or at least the line that goes to the throttle body. That vacuum piece is a thermac sensor that operates your stock air cleaner heat riser POS.
, Jon (350 TBI!)
91 Red My website
Old Sep 6, 2001 | 11:43 PM
colincamaro's Avatar
Hooker catback, sounds better than anything I've ever heard...worth every penny
89 RS 305 TBI/Hooker catback-hi flow cat/3.42 gears/ To import racers;there's no replacement for displacement!
Old Sep 7, 2001 | 11:07 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
i like my dynomax but it is quite, sounds simmilar to new vettes. with the cat removed i think it will be perfect.
Old Sep 7, 2001 | 12:22 PM
PopaPork's Avatar
I have flowmasters. POOOOPIE. That is all i will say about that.
89 RS Camaro
Hedman Headers, Highflow Cat, Flowmaster 80 Series
180 Degree Thermo
Open Air Element with K&N Air Filter
Custum Burned Chip
So Many Mods......so little time
www.rit.edu/~cjp8408
AIM: PopaPork
Old Sep 7, 2001 | 02:39 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
I'm all about my Dynomax cat-back. I've got Dynomax headers/y-pipe, no cat, and the 2.5" cat-back. It sounds right.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Sep 8, 2001 | 12:27 PM
snflupigus's Avatar
any sounds of that mark, i would like to hear the entire dynomax system.
Old Sep 8, 2001 | 03:31 PM
TMoNeE's Avatar
Car: 87 Z28
damn... my flowmaster sounds really good.. but i have heard quite a few that sound lamo.
92camaroJoe
Jul 29, 2023 07:57 PM
junkcltr
Aug 2, 2019 11:12 PM
pimp2303
Jul 27, 2017 02:03 PM
92camaroJoe
Aug 13, 2015 06:07 AM
