best chip for 350 tbi
Old Sep 17, 2001 | 07:20 PM
firbird's Avatar
i just want to know what is the best chip that can be made for a 350 tbi and where could i get it and how much it would run for.
thanks
350 tbi auto 330hp 350 crate with preformer rpm intake manifold, holley tbi unit, stock every thing else pretty much other than a open air element
Old Sep 18, 2001 | 10:07 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Ed Wright (ewright@silverback.gorilla.net)
burns the best (fastest) custom chips in my opinion. Check out fastchip website for more info(www.fastchip.com). In my opinion nobody else comes close.
1992 RS,5 Speed,T-Tops,Eibach Springs(cut), KYB's, Lakewood Trailing Arms and Adjustable Panhard Bar,Posi Disc Rear,3.73 Gears,Summit Rearend Support Cover,
Del-A-Lum Bushings,300 HP Crate Motor,Crane Comp-U-Cam,Edelbrock TBI Intake, Turbo City Ported Throttle Body and Adjustable Fuel Pressure Regulator,Open Element
Air Cleaner, Ground Control Strut Tower Brace and Caster/Camber Adjusters,SLP 1-5/8" Headers,Flowmaster 3" American Thunder Exhaust,3" Cat,Centerforce Dual
Friction Clutch,Hayes Billet Flywheel,B&M Power Steering Cooler,Big Thumpin' Stereo.
Old Sep 19, 2001 | 12:49 AM
JPrevost's Avatar
Car: 91 Red Sled
Sounds like you've got my engine...hmm....
, Jon (350 TBI!)
91 Red My website
Old Sep 19, 2001 | 10:42 AM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
Unless you work something out with Jon here. I would reccomend the ANLU chip from and 89 police car. that is only assuming that you have the 8746 ECM whch is the same as Jon. I know I started with that BIN in my 305 and I'm pretty Sure that Jon started wiht it as well. It's definately a good bin you can get one from the Dealer for prolly less than $50
-Lars
Old Sep 19, 2001 | 09:27 PM
firbird's Avatar
well jon has givin me a deal but i have herd complains from him about he cant get it right or something but yea jon i have exactally the same. expect a email tomarrow
Old Sep 20, 2001 | 02:41 PM
JPrevost's Avatar
Car: 91 Red Sled
Major problem with the stock ANLU is the tcc unlocking tables. They're all FUBAR and makes your slushbox feel even MORE like a slushbox.
It is true that I'm having problems with my setup under WOT but I've located my problem....fuel pump. Fuel pressure is dropping down low after 4000rpm. So if I could program an eprom to replace my fuel pump I would .
, Jon (350 TBI!)
91 Red My website
Old Sep 20, 2001 | 05:00 PM
DM91RS's Avatar
Car: 91 RS
JP, I have not been following you posts on the trans programming. What are your problems?
Old Sep 20, 2001 | 09:08 PM
firbird's Avatar
damn it, i hate this stupid car, lol. i park my car and come back and the starter does not even try to attempt to turn my eninge, i had some aluminum foil covering the soinoid, maybe if touched the live wire going to the starter and blew all of the inline fuses going to it, but i herd that when this one guy here blew them that all the lights did not work, have not checked anything yet really other than reseting my computer in my battery to see it it will come back, too dark right now, hopefully it will be just a blown fuse or something under my dash, i can only hope, sounds like fun what ever it is.
cool i did not know it was the fuel pump, glad you found out what it was. wish computer would give you a new fuel pump and i wish the computer would give me a running car
Old Sep 21, 2001 | 12:03 PM
Brent's Avatar
<font face="Verdana, Arial" size="2">Fuel pressure is dropping down low after 4000rpm. </font>
Hmmm, that sounds familiar.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
Dwayne614
Sep 28, 2015 08:33 AM
Eric-86sc
Aug 24, 2015 09:01 PM
NWAsonoma
Aug 18, 2015 05:45 PM
