LT1 cam question
yes. '96-'97 I think.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
-Tas
'89 Formula WS-6
:Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
Axle/Gears: 3.45, 3.27, 3.27
Can you put in the LT1 cam without changing anything? Sure. Will it run better, I'm not sure. It depends on what other things you've done. As a comparison, I swapped in a '95 F-body LT1 cam and the car runs great! I'm still running the stock chip and injectors. The LT1 really complements the 3" cat-back and 1-5/8" SLP headers, WC T5 & 3.45 gears I'm using. Today I hooked up my vacuum adjustable fuel pressure meter. But I need to tweek it a bit. 12 psi at idle and 20 at WOT! (now stumbles when floored off idle due to too much fuel being injected). I forgot to mention I have a LT1 fuel pump I installed in the tank. We ran the scan tool and found the stock chip is still handling everything fine. Bottom line, you may need a custom chip burned to take advantage of the cam. But this is a great mod that will wake up your engine.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
90 RS Convertible
(626)369-0040
Hey lonsal:
Did you replace the valve springs?
Mine have a lot of miles on them but appear to be in ok shape.. I'm almost done with my cam swap, (praying that nothing bad happens to engine)....
Only think i'm not 100% sure on is the valve lash..
Car: 91 RS
Lonsal, do you have the stock heads and intake. I am going to try an LT4 that I have but do not know if it will do any good without changing the intake or heads. The breather flows well and I have headers and 3" exhaust. 5spd 3:08 Thanks for any info on the 305. My 350 HO just **** itself
91 RS L31 350..... Vortec heads..... Holley 670..... Edel. intake .... Lt4 cam 1.6 rollers ..... Edel. TES headers .. 3" exhaust ..... 5spd 3.08
Re-used stock springs (103K on them). Stock intake & heads. I tested it at the track yesterday and ran 15.495 @ 89.62 mph. Prior to swapping the cam it ran 15.694 @ 87.51 mph. Good luck with your swaps. It is worth it. Lon
90 RS Convertible
(626)369-0040
90 RS Convertible
(626)369-0040
Car: 91 RS
Thanks for the reply Lon
I'm glad to see that it made a differance. I going to do the swap and I just have to decide if I will change the rockers to 1.6 Cranes that I have and change the intake. Any opinions?
91 RS 5.0 TBI....Edel. TES headers .. 3" exhaust ..... 5spd 3.08
I'm glad to see that it made a differance. I going to do the swap and I just have to decide if I will change the rockers to 1.6 Cranes that I have and change the intake. Any opinions?------------------
I don't know if I would go with an Lt1 cam and 1.6 RR's on the stock springs.. they are close already with just the lt1 cam.. with 1.6 rockers, you increase the lift another .03".. that could be bad...
Car: 91 RS
I will be changing the springs either way. Might even stick my Vortec's on there. Any thought's on LT4 cam, 1.6 rollers rockers, Vortec heads, Edel Vortec intake on the 305? I know about the compression drop but I'm not milling them. I will use a GM composition .028 head gasket for what it's worth. It has to kick the peanut right off the planet. Not like having the 350 back but that's for spring time.
