tbi tpi heads
Old Apr 22, 2007 | 08:01 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
tbi tpi heads
i was reading something about swapping tbi to tpi heads, i guess this is suppose to help the stocker run. i was also under the influence that tpi heads flow worse than tbi heads?? so why should i put tpi heads on my tbi car?
Old Apr 22, 2007 | 08:10 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: tbi tpi heads
They flow slightly less on the exhaust side and more on the intake side, mainly at higher lift. Under 275 hp and it's a wash as to which head will make more power. Above that and the TPI head has the advantage, much past 325 hp and you are much much better off with vortec or aftermarket heads.
Old Apr 22, 2007 | 08:20 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Re: tbi tpi heads
so do you suggest swapping these tbi heads with tpi on my nearly stocker? i am gonna do the lt1 cam a set of headers full exhaust and hopefully some kind of different or better upgraded tbi intake. ALSO>>take you up on that tuning idea. my winaldl cable will be here soon so i can start data logging. next step is read more stickies, order burner and flash chips (if thats all i need) and start burning. so anyway sorry that took so long,,tbi to tpi heads?
Old Apr 23, 2007 | 04:30 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Re: tbi tpi heads
ttt
Old Apr 23, 2007 | 09:10 PM
BMmonteSS's Avatar
Car: 84' Monte
Re: tbi tpi heads
On a near stocker.....I would stick with the TBI heads. The LT1 cam will help raise the power band, but no where near too high for the swirl ports.
Like I said money would be much better spent on vortec or aftermarket heads, and most deffinately get into tuning.
Old Apr 23, 2007 | 11:10 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Re: tbi tpi heads
just cut the deal on an LT1 cam for 40 shipped. possibly hedmen shorties wit y pipe for 120 as well. all used but should be what i need. tuning will come in a few weeks. im pretty sure i dont neeed to tune with the cam and new exhaust. not yet anyway even though i know it will help. do you know what i need to do before tuning to put tha cam to good use?
Old Apr 23, 2007 | 11:49 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Re: tbi tpi heads
see if you cant find later alum tpi vette heads instead of the iron tpi ones.
Or consider vortec.
Old Apr 24, 2007 | 12:21 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Re: tbi tpi heads
i probably wont go vortec cuz that takes different intake right away im assuming. and monte said that tpi heads would do me nearly no good with my almost stocker
Old Apr 24, 2007 | 04:07 PM
BMmonteSS's Avatar
Car: 84' Monte
Re: tbi tpi heads
You'll re-examine whay you consider as "need" once you get the car running on the cam. Some guys say they get around just fine, while other have a heck of a time even getting the car to idle.
In my book I wouldn't do the cam swap without tuning. You'll be giving up a LOT of power, and your gas mileage and drivability is going to go down the tubes. Anything you do now to help the engine breath is just going to make it worse.
Once you get tuning, the next step is going to be to open up the intake tract.
Old Apr 24, 2007 | 04:26 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Re: tbi tpi heads
in that case i screwed up because i ordered my exhaust before my aldl cable. i was under the impression that no tuning would be required to open up the exhaust. my bad
Old Apr 27, 2007 | 07:08 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Re: tbi tpi heads
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
gta90
Sep 15, 2015 04:00 PM
Sanjay
Aug 12, 2015 03:41 PM
