1991 rs 305 tbi need help with mods
Old Apr 27, 2007 | 06:59 PM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
i have a 91 rs 305 tbi i have the full msd set up flowmaster cat back and higher stall torque converter. i am planning on buying the hypertech chip with 160 degree thermostat has anyone had any good results also what other easy mods are there to do like tbi spaser and injector spacer that would add power and make it sound better
Old Apr 27, 2007 | 07:49 PM
Rocket-Doc's Avatar
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
Re: 1991 rs 305 tbi need help with mods
Does anyone read the stickey's .....
Save your money on the other stuff....
Learn how to tune.......
Then put other stuff on...
Old Apr 27, 2007 | 07:50 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
your best bet would to not buy a chip, replace the thermostat with something colder on your own and start tuning your own car. it will save you money in the long run. yes this setup will help you alot especially with the exhaust and ignition. next step i would go is cam, lt1, or performance cam. then air. that car needs to have good lungs to breath. in order to accomplish that you need air coming in as fast as its allowed to go out so either set up some kind of cold air intake on there or go open element or if your really handy fab your own ram air.
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
Dwayne614
Sep 28, 2015 08:33 AM
92purpz28
Aug 11, 2015 02:30 PM
