Hungry for more power; not sure where to go
Old Nov 5, 2001 | 12:42 PM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
I've done some easy bolt-on mods - underdrive pulleys, open element, TBI spacer, Hypertech chip. I have everything well maintained (with "performance" cap &plugs and 8.5mm wires, all fluids, filters, new tires, yadayada). The G-Tech is only showing 159hp at the rear wheels (minus drag and all).
I'm thinking to get a cat-back, then headers next (headers 2nd cause I can't make time to do them right now). But I am also pondering a new intake, maybe a better cam, maybe even gears. I had been thinking about ignition mods, but I don't get the impression that it would make a worthwhile difference.
I've never done any of these mods, so I don't really know which would give me the best results. Any of you more experienced guys care to weigh in?
Joel Geerling
Red 91 Formula, 305 TBI
Edelbrock 14x3 open element
TBI 1/2" spacer
Hypertech street chip
Crank/Alt Pulleys Exhaust is next!
Old Nov 5, 2001 | 01:52 PM
JPrevost's Avatar
Car: 91 Red Sled
I would probably do exhaust because it's the easiest out of the mods listed. Also probably end up being the cheapest. The intake and Lt1 cam swap wouldn't cost much but it would take some time and removal of the radiator. I've listed this probably a hundred times: My list of things I would do in order (if I didn't have experience working on cars), Gears w/posi, headers/exhaust work, intake w/Lt1 cam. That is my extent as to how far I personally would go with the Lo3. Some guys like going further and doing a more radical cam, intake, heads, larger TB unit. I do recommend if you haven't already, getting an open element air cleaner (drop base 14x3) and doing the adjustable fuel pressure regulator!
Old Nov 5, 2001 | 04:32 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I agree with JPrevost.Gears w/posi,headers/exhaust,intake/cam if you don't already have an open element air cleaner and adjustable fuel pressure regulator.
Rich
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
