regulator question
Car: 88sc
Engine: 305 for now
Axle/Gears: peg
regulator question
for you guys running higher fuel pressures (15-30+), what are you using for a fuel pressure regulator? i'm assuming that the stock unit, even if modded for adjustability, won't set these higher pressures?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: regulator question
I use a GM 454 TBI regulator. I use a different spring (stock one too weak, 454 one too strong) but I cannot remember where I got it from (top down solutions maybe?)
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Hey Shifty, what pressure are you running with your TBI??? Also, what is a good starting pressure??? Thanks, Tom
Car: '90 RS
Engine: 377 LSX
Years ago before my cam swap I was running the stock pump and roughly bumped the pressure 1 PSI or so (was learning the basics of tuning). You won't get much past 12psi with the stock pump. With an aftermarket pump you can run much higher pressures. It all boils down to what fuel injectors you use and the combo you have to accuratly dial in the fuel pressure. My car hasn't run in years (new project but should have motor running in the next few months) and honestly I am not sure what my last set-up entailed.
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
Hold on a second. I just realized something. Is the Fuel Pressure the Same at idle as WOT? Ive got my Regulator maxed out. Dont know the exact pressure. Stock L03.
Car: 89 S10 Blazer
Engine: 355 tbi
Transmission: Built 700R4 w/ 2500 stall
Axle/Gears: 3:73 posi
Yes, they are not varialble regulators so it will be steady psi.
As long as it doesnt dip down at wot your doing good.
Car: 89 RS, 92 Z28
I still have the stock pump......I dont think it would be the same at idle, as it would be at WOT..........Shifty, did you use 350 truck injectors?????????? I was told they would work better with the LT1 cam....So i got a set, please let me know what you think, as I respect your opinion....I think the thinking behind that is that they will not be working as hard as the stock 305 injectors...Makes sense to me, I think they can cycle, even if they dont really put out much more.....I am changing cam this week, and I rebuilt the 350 truck injectors to put in at the same time...Am going to have my chip redone to match..(I know, should do it myself) I will data log, and do that soon, but for now, I hope it is at least workable.....Thanks, Tom
Car: 89 S10 Blazer
Engine: 355 tbi
Car: 89 RS, 92 Z28
BTW, just made my reg adjustable when I did the TBI rebuild......
Car: 89 S10 Blazer
Engine: 355 tbi
Oh im sorry, i meant to say VARIABLE fpr, the ones that have a vaccume line attached. my bad.
But no, if you have the right pump for your setup, it should stay the EXACT fuel pressure no matter what.
Car: 89 RS, 92 Z28
Ok, got ya.....It is great in theory...I do need to get a different pump, my stocker is taxed to the max, im sure,Tom
