Need advice 305 lt1 swap
Ok..did the swap...was told i need new valve srings....do i? if so what kinda i dont want $$$ ones....maybe 50.00 would that get a good set.....and i have to get new valve seals also...any tips on installing them?
please help...if you know what i need or have done this swap
just do both at the same time. if you are plaaning to do this with the heads on the car you ar gonna need an air compressor to pressurize the cyls. it is an easy job, it just takes a whilke to do.
later
tim
91 Camaro RS-LO3,Auto
New Times Coming Soon!
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
later
tim
Car: 92RS
Engine: 357
I've put on about 5000 miles since my cam swap,probably hit 6000rpm at least 100 times.Still running my stock springs with no trouble.I guess if I was going to change valve seals I would change the springs also.Otherwise I myself wouldn't worry about it.
92RS LO3 700R4
open air element
ultimate TBI mods
LT1 cam
Edelbrock TBI performer manifold
180 thermostat
Hooker headers
3"cat back
Zexel Torsen posi with 3.42 gears
[This message has been edited by JokerRS (edited November 30, 2001).]
92RS LO3 700R4
open air element
ultimate TBI mods
LT1 cam
180 thermostat
Hooker headers
3"cat back
its really good to know somebody has the same question i do, i havent had my car on the road yet with my LT1 cam, i called Jim Pace GM performance in northern ohio, and they said our stock springs will handle the LT1 cams lift specs, now i was under the impression that more lift would mean more spring pressure, but if what your tellingis true about reving out your engine and have 5000miles on the cam, i guess our springs can survive, and also valve seal are so easy to do, and summit carries a spring set for $57 if you dont feel safe using stock springs, im going replace my rocker arm with roller tip 1.5 ratio, spring for new push rods also, also one other question whats Redline point on the LT1 cam, if someone with the answer can e-mail me i'd apreciate it, my e-mail is Londonafermid21@aol.com thanks!!!
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
What is everyone doing about lifters when they do the lt1 swap?
Chuck Kulchar
1991 RS
Open Element w/K&N
3" cat and Force II cat-back
Chuck Kulchar
1991 RS
Open Element w/K&N
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
<font face="Verdana, Arial" size="2">Originally posted by Chuck!:
</font>
</font>
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH (2.10 60')
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Car: 92RS
Engine: 357
My lifters looked fine so I reused them .By the way,while the cam did help increase power,it didn't add as much as I thought it might.I think this is because I'm still running the swirl port heads.I plan on going to vortecs some day,but they will be sitting on a 383 crate motor.My biggest power increase came from full exaust mods.
Later,Dave
92RS LO3 700R4
open air element
ultimate TBI mods
LT1 cam
180 thermostat
Hooker headers
3"cat back
Later,Dave
92RS LO3 700R4
open air element
ultimate TBI mods
LT1 cam
180 thermostat
Hooker headers
3"cat back
