Maybe A Misfire?
Old May 18, 2007 | 03:08 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Maybe A Misfire?
I have a 89 rs, 305/TBI
I have replaced the wires/spark plugs/coil pack/ distrib cap. I start it up, it runs very rough, but stays at a semi consistant Idle. I took it on the road, smashed that baby and it felt like i had a 1.0 ltr in a 8000 lb car, it had no power, but when it shifted gears it was like BAM hardcore power then its gone, only has decent slam when it changes gears. I removed my throttle body and one of the vac lines was pretty plugged up so im cleaning this as we speak, what im trying to ask anyone have a clue what the problem could be, its not popping any codes, im gonna try the clean TBI tonight hope it works but probably wont. I dont know what could be wrong, its like its totaly misfire'n but i have pulled 1 plug at a time and started it and seen spark, i double checked all gaps on plugs, I know i put my wires in the correct spot, ran a compression test on all cyl's about 150 for all them..... Im totaly clueless please help !!
Doug
Old May 18, 2007 | 03:55 PM
1Bad3rdGen's Avatar
Car: 92 Firebird Convert & 91 Camaro RS
Engine: 305 L03 TBI
Transmission: 700r4 & T5
Axle/Gears: Stock
Re: Maybe A Misfire?
to me it sounds like your ecm is retarding your timing! it may be numerous things. your knock sensor picking up knock. you have an exhaust leak. your egr. do you have any aldl cable to datalogg the car? when you are under load do you here any rattling from the engine? pinging? it could be your timing.
Joseph
Old May 21, 2007 | 09:20 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
I dont have a AlDL cable. What would be the easiest way to see if its the timing, mess with the Cap by turning it? I cant tell if there is any ratteling cuz the car is like shaking when under a load. Another thing, should i take the knock sensor off the engine and then try just to eliminate that idea?
I dont think I have an exhaust leak, you should be able to smell it if ur up under the hood for a while with it running? plus i dont hear anything that sounds like exhaust in the engine bay.
Would the EGR valve really do all that?
Doug
db057
Jan 10, 2020 08:55 PM
NZKnight
Oct 15, 2015 02:47 PM
camarohelp
Sep 22, 2015 03:19 PM
Jk_Under
Sep 8, 2015 08:13 AM
Thaney9
Aug 29, 2015 03:16 PM
