Fuel Pressure Regulator
Old May 20, 2007 | 12:22 AM
Upshotunity's Avatar
Car: 1988 Camaro
Engine: 5.0L TBI
I need to change my fuel pressure regulator but I can not find one anywhere. Does anybody know where I can pick one up from I have looked everywhere including local parts store. It does not matter if it is a adjustable or non adjustable I just would like the whole regulator. It is for a 88 305 TBI. If anybody knows a website or anything please let me konw thanx.
If I am not able to find one I was thinking of disengaging the stock one and installing a inline regulator. Any pointers and help on this would be nice.
Old May 20, 2007 | 12:25 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
Re: Fuel Pressure Regulator
why? and you should be able to get one from a lot of places on the net. adjustable are going to be easier to find than stock. Unless you go to a dealer.
Old May 20, 2007 | 03:14 PM
Car: 1988 Camaro
Engine: 5.0L TBI
Don't you think that is the reason I am writing here because I can't find one anywhere on the net for a 305 TBI. And if I am going to need to put on an adjustable one I need to know how to disengage the stock on and install an inline regulator.
Old May 20, 2007 | 03:53 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
autopartsgiant.com. Follow the prompts for your model and year. Pick a 94-95 TBI'd 454 truck if you want teh high pressure version.
Old May 20, 2007 | 07:56 PM
snflupigus's Avatar
i mean why do you need to change it... and when you say whole regulator are you mistaken and really meaning the entire injector pod assembly?
I'm asking because the regulator isnt typically a part that wears out or breaks... and when you say "the whole regulator" - have you found just the spring, just the diaphram, and just the shell seperately somewhere?
anyway.... just trying to help.
http://www.google.com/products?q=tbi...ator+305&hl=en
googled it... not that tough to find them.
my point before was that if you explain a bit more of what issue you are dealing with and trying to work through or around... we all could provide better help to you.
Old May 20, 2007 | 08:03 PM
Car: 1988 Camaro
Engine: 5.0L TBI
I have found the diaphram. I need to replace the regulator shell and spring. The owner befor tried to do the adjustable mod and bent it all up and it looks pretty messed up. I just need to replace it and the spring I already have the diaphram.
Thanx for the help.
Old May 20, 2007 | 08:09 PM
Car: 1988 Camaro
Engine: 5.0L TBI
Hey thanx snf I checked out your link and just what I needed right at the top. I appreciate your help. Will be ordering right now.
Old May 24, 2007 | 09:28 PM
Car: 1988 Camaro
Engine: 5.0L TBI
O.K. guy I got the adjustable fuel pressure regulator and installed it already. How can I adjust it for the right fuel to air ratio. I tried using the tech article using a multimeter, but couldn't get it. I don't know if I was doing it wrong or what but the voltage kept jumping aroung so I couldn't get an accurate or baseline reading.
Any help?
Old May 25, 2007 | 09:17 AM
Car: 88 Camaro SC
Engine: SFI'd 350
The ECM is in closed loop, so the O2 voltage will go all over the place as its making corrections to the fueling. Hook up a scantool and try to get the BLMs close to 128 with the fuel pressure adjustments.
Old May 25, 2007 | 10:40 AM
Car: 1988 Camaro
Engine: 5.0L TBI
not to sound like a moron but I am not exactly sure what a scantool is and where to get one and I have no clue to what BLM's are.
Can you elaborate?
Sorry.
Old May 25, 2007 | 10:58 PM
snflupigus's Avatar
blm is a term for something the computer uses to adjust the air/fuel ratio...
if I were you I would get an adapter for a fuel pressure gauge and just set it to 13 or 14 and the computer will get you to good if your car isnt modified too much.
http://marine-performance-parts.com/...843505774.aspx
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
