Stock TBI intake
Old May 20, 2007 | 04:54 PM
beatercoprice's Avatar
Car: 92 & 93 caprice 9c1's
Engine: L05's
Transmission: 4L60's
Axle/Gears: 3.42's one G80, one open
Stock TBI intake
Are they all the same? Obviously the ones for caprices are differant where the distributor mounts, but is that the only differance?
Where/when does a stock or "gasket matched" TBI intake run out of breath? How much power can they support?
Old May 20, 2007 | 06:49 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: Stock TBI intake
Last time I checked the dissy was mounted the same in every small block chevy made up untill the LT-1.....which didn't have one.
The stock intake has been used on motors up to 300hp (ask fast355) this doesn't mean that it isn't restricting power. I would only look to the intake untill you've done the full exhuast, cam, and tuning. Only then does it become cost effective.
Old May 20, 2007 | 07:07 PM
Engine: L05's
The 91-93 caprice used a special shorter distributer with a bigger opening in the intake.
Old May 20, 2007 | 08:27 PM
BMmonteSS's Avatar
Car: 84' Monte
Huh.....Learn somethin new everyday.
If you have the room, which I think you do, I would run a performer RPM. Just can't beat it for a street engine.
Old May 20, 2007 | 10:30 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
They are not shorter - but the top flange has a larger diameter on B-body. This was done to allow for in car removal. I'll post pics later on.
//RF
Old May 21, 2007 | 07:12 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
//RF
I think there is a length difference.... but I haven't measured them myself. The mounting flange is the more obvious difference.
Here are the threads on the flange issue:
https://www.thirdgen.org/forums/tbi/...ntake-my.html?
https://www.thirdgen.org/forums/tech...g-m-make.html?
https://www.thirdgen.org/forums/tpi/...Caprice+flange
Old May 21, 2007 | 10:18 AM
RFmaster's Avatar
Car: 75 Beast
Kdorolt
I guess I was wrong . I have the following three distributors.
1103460 'Pulled from 86 camaro LG4 CCC Standard Hat
1103952 'Pulled from 89 TBI LO3 Camaro
1103852 'Pulled 91 305 B-Body
Top collar diameter (distro shaft to intake manifold):
'3460 1.25"
'3952 1.25"
'3852 2.10"
Distance from top collar bottom flange to top block sleeve (there are two):
'3460 4.47"
'3952 4.47"
'3852 4.30"
It appear as B-Body intake manifold distributor through flange is thinner and wider to make distributor removal easier. One way to make sure is to measure intake manifold flange height. I'll post photos tonight explaining my dimensions.
//RF
Attached Thumbnails Stock TBI intake-photo-054-cropt.jpg   Stock TBI intake-photo-053-cropt.jpg   Stock TBI intake-photo-052-crop2t.jpg
Old May 21, 2007 | 08:39 PM
RFmaster's Avatar
Car: 75 Beast
Now complete
Left To Right Line up
//RF
Old May 22, 2007 | 04:12 AM
Engine: L05's
As you can imagine it kinda makes it a PITA for us 91-93 B-body guys. Nobody makes an aftermarket intake thats works with this distributor. The other type will work but you wont be able to remove it without pulling the intake.
Old May 22, 2007 | 01:42 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
Then why not just bore out the manifold to the B-body specs?? Removal of material is easy and free(usually), just kills the resale value. Maybe I'm way off base, but from what I gather, its just a larger mounting flange on the B-dizzy.
Old May 22, 2007 | 02:46 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Could you just use a b-body intake with a b-body distributor or a f-body intake with a f-body distributor in either vehicle? I maybe be wrong, but didn't sbc trucks of the same era use the b-body distributor too?
Old May 22, 2007 | 02:54 PM
RFmaster's Avatar
Car: 75 Beast
It is possible, but you will need to CNC intake manifold - to precisely locate the center line of existing distributor through hole. Bottom and top sleeves bore centerlines have to align, or otherwise distributor will never sit straight in.
Also, you will have to take out 170 mills of top side of intake manifold flange so that distributor can sit lower. I do not know if standard intake manifold flange has that much meat to take out.
//RF
Old Jun 11, 2010 | 03:34 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
trucks used small hole distrib and intake.
cars used larger hole intake and distrib....
just did a replacement of 305 in a '91 pickup with a '90 car 305 and foiund out about all this.....
fun....
retarded toooo...
bock and heads same casting numbers
intakes different only for distrib hole size.....
MustangBeater20
Oct 29, 2022 09:20 PM
dutch930
Sep 11, 2015 06:58 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
