I can't get my pully off my water pump!! Can someone help?
Old Dec 13, 2001 | 07:00 PM
un4givin89's Avatar
I've already removed the pump itself and the belt. I tried loosening the pully when it was on, but it wouldn't move. I have it off now and it still won't move.
un4givin89
Poor Mans White Face Guages
MikeKey.net - Camaro Enthusiast
Old Dec 13, 2001 | 09:31 PM
deadtrend1's Avatar
it took me and a friend to remove it from mine a week ago, but i had to put the belt back on it first, him hold with both hands, i held with one and and cranked the rachet. Maybe I'm just weak. Try a vice or something, and have someone else hold it.
1991 Firebird (GT40)
-LO3 305 TBI
-5 speed
-Open Element Air Filter
-Edelbrock Tower Strut Brace
-Kenwood Excelon Headunit w/ 10 Disc Changer
-Alpine MRP-F256 Amp
-Polk EX 4x6's, DX 6x9's, and EX Tweeters
-Kicker ZR240 amp (bridged)
-Dual JL W0 12" Subs
My page with pics and stuff, and car stereo help.
http://members.aol.com/deadtrend1/index.html
Old Dec 13, 2001 | 09:33 PM
deadtrend1's Avatar
-LO3 305 TBI
-5 speed
Old Dec 13, 2001 | 09:34 PM
deadtrend1's Avatar
sorry about the double reply, my web froze for a second, had to hit the refresh button and that happened. stupid AOL, and stupid Dial-up!!!!!!!!!
Old Dec 13, 2001 | 10:19 PM
NJ SPEEDER's Avatar
one thing to do is to not try to "turn" it so to speak. instead, put the wrench on the bolt, hold the pulley still with your left hand and hit the wrench witht he palm of your hand to kind of shock it loose. spraying a bit of pb breaks loose or some other penatrating oil on the bolts always helps too.
later
tim
91 Camaro RS-LO3,Auto
New Times Coming Soon!
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Dec 13, 2001 | 10:43 PM
Rock90rs's Avatar
Car: 92 RS/90' vette
Engine: Heads/cam/miniram/blah blah blah..
Transmission: T5/700!
Axle/Gears: 3.08
Thats why I own an impact wrench.
1990 RS
V8/A4
White/Primer ....Project in the works
1998 Z28
M6/!cags
MTI lid w/k&n
Magnaflow catback
HPP
Underdrive pulley
78 Chevy Fullsize
355 11:0:1
Trickflows, 282/282 .580/.580,, supercomps,torquer, holley 700 DP
Big Bad Sleeper
**Previous Rides**
1990 RS
1985 Berlinetta
Old Dec 14, 2001 | 10:12 AM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
Use an Impact gun. It will knock it right off.
Old Dec 14, 2001 | 12:32 PM
un4givin89's Avatar
I don't have one, and I'm not buying a 80 dollar and up impact gun..
Old Dec 14, 2001 | 01:00 PM
Nitroburn's Avatar
This is a trick I used to use....
Take a small pry bar (one that has a square shank if you can) and place the end of the pry bar up against the center nipple that is sticking thru the pully and hold the pry against on of the bolt heads. Choose one of the other bolts and loosen it. Do this for all of the bolts.
You don't want to take the bolts out, just break them loose as you will need to utilize some of the already loose bolts to break the others free.
You could also use a good, thick, long flat-head screw driver.
Also, the longer the pry bar/screw driver is and the longer the ratchet/wrench is the easier it'll be to break them loose.
Mike
89 T-Top Firebird 305 TBI Project Car (with approval from my wife!)
Old Dec 14, 2001 | 06:04 PM
Jza's Avatar
Jza
Then get a $20 Harbor Freight impact gun. It works fine for a home mechanic.
Old Dec 14, 2001 | 06:17 PM
un4givin89's Avatar
I bought myself some billet pulleys.
evilstuie
Jan 9, 2020 08:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
