doesn't want to crank over
Old Jul 13, 2007 | 04:13 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
ok new battery ,starter . if i put the dist in one spot it turns over and runs but if i try setting advance (moving dissy) it doesn't want to turn over.
Old Jul 13, 2007 | 04:21 PM
deadtrend1's Avatar
Re: doesn't want to crank over
firing order correct? and are you pulling the EST wire when setting timing?
Anything else done to the motor that may affect it?
Old Jul 13, 2007 | 04:47 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
firing order correct ,est off. it acts almost like it vapor locks or something but i dont run it long enough for that.
Old Jul 13, 2007 | 05:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Your timing is advanced much too far when it won't turn over.
Old Jul 13, 2007 | 06:30 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
don't mean to be a pill,but my dad says its a tooth off but how can i get it right on when the dissy only goes in so mant ways.
Old Jul 13, 2007 | 06:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Have you removed the distributor?
Old Jul 13, 2007 | 07:37 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
yes i put this new one in it,at first i had it 180 out. now it'll start but only in the 1 position, other wise it will do the afored mentioned.
Old Jul 13, 2007 | 08:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Bring the engine to #1 TDC firing first.
Then you can install the distributor, put the #1 plug wire on whichever terminal on the cap that the rotor is pointing at, and put the rest of the wires on in order from there.
Or, you can use a long flat screwdriver to turn the oil pump drive shaft until it lets you put the distributor in so that it's aligned with the terminal on the cap that you want to be #1.
Old Jul 14, 2007 | 09:13 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i m just about to give up, i know its close to being time yet once again it just cranks and cranks and does nothing.
Old Jul 14, 2007 | 01:39 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
well guess what? the dam thing isnt getting e nuff fuel .
Old Jul 15, 2007 | 06:09 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
now this is retarded ,when trying to crank over car girlfriend asked me why gas only comes out of 1 injector,(not being able to see the one on passenger side) i had no clue it wasn't firing.
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
angel2794
Sep 8, 2015 06:22 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Formula_88AE
Sep 3, 2015 01:47 PM
