JUST ORDERD FLASH EBL
Car: 89 Camaro Convert,89 Camaro hardtop
Engine: 305 and a 357
Transmission: 700R4,T5
Axle/Gears: 4.10's and 3.43's
as the title say i just orderd one any one else have one yet im excited gonna get the lt1 cam swap running right needed a new computer any ways had a glitch in it
Re: JUST ORDERD FLASH EBL
The EBL is by far the best mod I've done to my truck. I wouldn't have started my engine swap/truck project without it. Tuning is so easy it's like your're cheating...!!!
Anyway, works great. Escpecially the no chip part!! I have a USB cable routed up into the console of my truck and that's it. Just plug in a go!
that was one thing i was thinking about if it used a serial cable or usb thats cool that it uses usb
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
Wow, I hadn't heard of this new devlopment yet. I'm glad I waited! Looks like I'll be getting one of these sooner rather than later.
Car: check
Engine: check
Transmission: check
If your laptop doesn't have a serial port there are inexpensive serial-to-USB convertors on the market that work. If a serial-to-USB cable is required it is up to the user to provide it.
RBob.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
will I still need an emulator ,i.e ostrich, autoprom to burn with or can I just use this with my laptop and wideband to burn with?
Car: check
Engine: check
Transmission: check
Basically have the data logging cable (included) connected to your laptop, WUD running, select the flash display screen on the WUD, give it the BIN name, which bank (holds up to 8 calibrations), and press the apply button. With a verify it takes about 1.5 seconds to program a new BIN.
RBob.
Car: 1993 Caprice LTZ
Engine: 350 TBI
Transmission: 4L60 (700R4)
I was awe struck the first time I seen the EBL system...now I can't imagine how awesome the Flash set up will be...
Kudos to RBob....
JB
Kudos to RBob....
JB
just came via ups about to hook it up but first a serial to usb connector is needed so ill post later about how awesome it is
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Well, this my completed conversion (2007-08-31) to FLASH EBL. Original ECM was a lowly 16136965 from LO3 91 Caprice. 6965 was chosen over 7747 because it has IAT input. Will try it tonight - next week.
//RF
//RF
Car: 87 Suburban 2500
Engine: 455 Wildcat ( somewhat modified ))
Transmission: TH400 ( for now )
Axle/Gears: 4.10 ( for now )
Well, I too, have acquired an EBL flash.
Rbob already knows this.
The only thing I have to add, is that I believe it's SEVERELY underpriced.
That, of course, is just me.
I'll be getting one next week! I can't wait to FINALLY start tuning.
