Did I fry the ECU or is there some other problem?
Old Aug 29, 2007 | 04:02 PM
mrogers's Avatar
Car: '87 Camaro
Engine: 4.3L V6
Axle/Gears: 3.08
I'll try to be brief. I swapped a TBI motor from a running vehicle including the engine wiring harness. Started up normal the first time for a few seconds and everything was fine. Second time an hour or so later it needed throttle to start like the IAC wasn't working but I'm sure its functioning because it regulates the idle at 600 RPM which isn't enough to start a cold engine or keep it running right, AND it now has an RPM dependant shake it didn't have the first time I started it. I'm stumped, please help.
Old Aug 30, 2007 | 10:18 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Did I fry the ECU or is there some other problem?
If the SES flashes once when you turn the key to the on position, then the ECM is at least working internally. If its a steady SES, its hosed or there is a power distribution problem.
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
383cam
Sep 9, 2015 06:01 AM
Glowsock
Sep 6, 2015 06:40 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
