$2,000 4 barrel tbi
Old Sep 27, 2007 | 02:03 AM
eschevyrda's Avatar
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
$2,000 4 barrel tbi
http://store.summitracing.com/partde...5&autoview=sku
ahh first time i see this
that price is ridiculous
what do you guys think
Old Sep 27, 2007 | 02:59 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Re: $2,000 4 barrel tbi
Available in single and dual versions, these ACCEL DFI 4-barrel TBI spark fuel management systems for GM include the ECM, harness, throttle body assembly/assemblies, air cleaner, fuel pump, fuel filter, sensors, and linkage hardware.
It's basically a MPFI setup for a carb'd car that wants to upgrade. It definitely makes it a lot easier to upgrade, rather than having to hunt down all the parts, and as such, demands a small premium, while also having the ACCEL name on it, demanding a little more premium.
That, and you can run some of the super-performance carb manifolds with no modifications, dunno if that's the case with the stock TBI.
Old Sep 27, 2007 | 08:25 AM
eschevyrda's Avatar
Car: 89camaro rs
yea it comes with everything but i think the the edlbrock set up is cheaper even the the holly commander system is still alot cheaper then that one
Old Sep 27, 2007 | 12:06 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
If I was about to drop the 2 grand on something like that, I would just save the other $1k for a Mass-flo EFI unit which is FAR superior to any aftermarket TBI system.
Old Sep 28, 2007 | 12:07 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Isn't that system basically a ford ECU with a chopped LS1 MAF and a freq. to voltage converter?
Old Sep 30, 2007 | 01:29 AM
Car: 91 RS
Engine: 350 TBI
What ever it is, it learns on its own and can suck up to 1000 cfm. As long as you're within the fuel limits on your chosen injectors it will go far beyond what any TBI unit can do.
Old Sep 30, 2007 | 01:36 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
You can get the TB unit by itself. The Accel part number is 74135B. I had one on my Weiand 142 blown 350. I think I paid $350 for the TB, then another $250 for injectors.
Old Sep 30, 2007 | 07:57 AM
Tbi-MAX's Avatar
for 2 grand... man ill just get this...
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
skinny z
Oct 5, 2015 06:23 PM
Gordonr1973
Sep 29, 2015 11:59 AM
