Pinging 305 tbi
Old Oct 3, 2007 | 07:36 AM
AUSSIE_CAMARO's Avatar
Car: 89 camaro
Transmission: auto
Axle/Gears: std
Pinging 305 tbi
hey guy's live in australia got a 305 tbi camaro 89 auto
not many people know about these cars here so i thought you guy's could help
itd just clocked 100,000 miles (all stock )and has started pinging unde light load
i've already set the timing to 0* as per specs & changed the plugs and tried the old water down the throttle body trick
is there anything i should check or are there any common problems that they suffer from ?
any help would be apreciated thanks guy's
Old Oct 9, 2007 | 10:08 PM
rocko350's Avatar
Car: 1991 caprice / 96 caprice
Engine: 4?? bbc / lt-1
Transmission: 700r4 / 4l60e
Axle/Gears: 4.10/ 3.73
Re: Pinging 305 tbi
check for proper operation of the egr valve. you need apply vacuum to the valve directly at idle and note any change with idle speed/sound. if no change then possible that diaphram has ruptured and loss of applied vacuum would be showing on vac pump guage, or the egr passages in the intake/heads could be clogged. you haven't by chance installed headers have you? you may need to install the lower backpressure one. can't remember the application right off hand that allows more flow. You could even have a fuel pressure issue. does it "fall on its face" at wide open throttle or just ping under light load.
and welcome to TGO
Old Oct 10, 2007 | 12:05 PM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
Re: Pinging 305 tbi
Mine has had at least a small amount of pinging pretty much since I bought it in March '06. More at times than others. I had my IAT sensor out of place for a while sue to my dual snorkel air cleaner and I'm that had to due with some of it.
Instead of water, try a top engine cleaner like GM's top engine cleaner or Seafoam. Make sure you are also using quality gasoline. If nothing else maybe run slightly more octane, but be sure you are using at least 87... I'm not sure what you guys have down under.
What did you gap your plugs at? I'm not even sure if that matters but when I recently replaced mine I gapped them slightly larger and it has pinged less since then. I think I gapped them at .040".
Old Oct 12, 2007 | 12:36 AM
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
Re: Pinging 305 tbi
and welcome to TGO
So, say if I just installed a Low Backpressure Exhaust system, and left the Stock EGR alone. I would have problems with pinging/falling on its face at WOT?
Old Oct 12, 2007 | 04:10 PM
DLV555's Avatar
Engine: 400 SBC
Axle/Gears: 4.10
Re: Pinging 305 tbi
I doubt it. I have headers and a 3" cat-back with no cat. Not much back pressure. My EGR works fine and my performance is great.
Old Oct 13, 2007 | 08:24 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: Pinging 305 tbi
Just so you guys know, the stock ecm listens and hears knock way before you could ever hear it. So if knock is getting bad enough for your to hear then there is probably something wrong with your knock sensor or it's just something rattling under the car.
Old Oct 13, 2007 | 09:40 AM
Car: 1991 Camaro RS
Re: Pinging 305 tbi
This may sound Retarded. Ive never changed a Knock sensor... Thats not the retarded part. Will Coolant or oil come out when changing a knock sensor?
Old Oct 13, 2007 | 10:59 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Pinging 305 tbi
KS is screwed into block drain hole - it is always in contact with coolant per-see. Get a bucket handy.
//RF
Old Oct 15, 2007 | 11:51 PM
rocko350's Avatar
Re: Pinging 305 tbi
no ive had some vehicles be sensative to proper low speed egr flow with some header packages. some egr valve applications are more sensative than others to higher or lower threshold opening vacuums and some others have preasure differential valves inside them to help start egr flow. as i stated i dont remember how to decipher the marks on the different valves. the lt1 valves for example come in 6 different "flavors"
any changes aussie?
xkingcodex
Feb 12, 2020 07:43 PM
Dwayne614
Sep 28, 2015 08:33 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
