gas milage lo3
Old Oct 5, 2007 | 08:04 PM
84bandit's Avatar
gas milage lo3
ok a 1992 camaro rs withan lo3 and a auto stock open diff and 16'' factory wheels, what type of gas milage could I expect from this car?
Old Oct 5, 2007 | 08:10 PM
Green92RS305's Avatar
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
Re: gas milage lo3
I used to get 27mpg in my '92 RS when doing 75mph on the highway. Then I got a drivers' side exhaust manifold leak and my gas mileage chit the bed. I didn't think RS's came with 16" rims from the factory, mine were the 15" rims with 215/65s.
Old Oct 5, 2007 | 08:26 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: gas milage lo3
My 91 RS came from the factory with the optional painted 16" wheels, according to the RPO list. Same with my buddies RS, factory 16" wheels.
Anyways, I get 16 1/2 to 21 MPG in my 91 RS, mostly city type driving, and I "play" with it often. I think the best mileage I've recorded has been @24-25 MPG
Old Oct 5, 2007 | 09:48 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
Re: gas milage lo3
my '92 came with 16" wheels.
i have been getting just about 22mpg combined driving. this should get better real soon, when i get my T5 in. for some reason my converter doesn't lock.
Old Oct 5, 2007 | 09:59 PM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
Re: gas milage lo3
If you're having a problem with gas mileage, then I would recommend that you change your o2 sensor. I did and it is like night and day.
Old Oct 5, 2007 | 11:01 PM
netfreak's Avatar
Car: 88 firebird
Engine: 305 TBI
Re: gas milage lo3
Same here. My mileage would keep changing regardless of how I was driving, and then while changing spark plugs I discovered the o2 sensor had broken in half... New one in and I've noticed the difference.
Old Oct 6, 2007 | 07:34 AM
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
Re: gas milage lo3
O2 along with other basic maint will make or break gas mileage. Start with some seafoam in the gas tank and crankcase, run til empty and change oil. Then use the rest of your can in the intake. Change the fuel filter, air cleaner, plugs, wires, rotor&cap, and 02 sensor (splice your own for less) and you should be gravy.
Old Oct 6, 2007 | 07:52 AM
Camaro Spectre's Avatar
Car: 91' Z28
Engine: 383 HSR
Axle/Gears: 4.11
Re: gas milage lo3
While I'm not an automatic I can squeeze a lot of gas milage out of my l03. I get about 25-30 in stop go traffic/rodding it on country roads & on the highway I can get anywhere from 30-35 maybe a little more & the engine has 161,*** miles on it so pretty good keeping right up with those fuel efficient cars.
Old Oct 9, 2007 | 09:37 PM
rocko350's Avatar
Car: 1991 caprice / 96 caprice
Engine: 4?? bbc / lt-1
Transmission: 700r4 / 4l60e
Axle/Gears: 4.10/ 3.73
Re: gas milage lo3
my 88 with 366,XXX mile was getting 26-30 before the rear locked up sending my car into the ditch. my timing chain was so damn wore out that the cam was like 18 degrees retarded. it had jumped a tooth but would run with the distributor clocked back a tooth. no low end at all. car totaled
Old Oct 9, 2007 | 10:27 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Re: gas milage lo3
That story makes baby Jesus cry.
Oh... I get around 16 in town and 25 on the road and I drive like a lead foot. These number will change for the worse when I swap rear axles. I'll be a touch faster, be able to break harder, and have better traction but my economy will suck more (pun intended).
Old Oct 9, 2007 | 11:07 PM
rocko350's Avatar
Re: gas milage lo3
my wife wanted to kick my butt. she thought i did it street racing til i showed her the parts in the diff. apparently the 2.73 peg leg don't like long burnouts or the forgetfulness of the owner for proper lubrication.
Old Oct 9, 2007 | 11:41 PM
krisb410's Avatar
Re: gas milage lo3
Old Oct 10, 2007 | 11:54 AM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
Re: gas milage lo3
Are you sure you did your math right? I've never heard of these motors averaging over 30mph. If so that's freaking awesome. The best I've ever averaged on one tank was ~28 mpg spending a whole day on the freeway. In normal driving (about half city/hwy) mine sees a high of 25mpg and about a low of 20. When it saw more city driving it averaged in the upper teens. My fuel economy barely changed at all after going from 2.73s to 3.42s. I'll probably be changing the O2 sensor in the near future.
Right now I have shorty headers, 3" catback exhaust, no cat, a dual snorkel aircleaner, and a taller truck K&N air filter.
Old Oct 10, 2007 | 12:20 PM
Car: 91' Z28
Engine: 383 HSR
Axle/Gears: 4.11
Re: gas milage lo3
Yeah, drove it from Hastings, Ne to North Platte, Ne and it only moved the needle about a quarter of a tank (from full to 3/4) and it was ~150 mile drive in about 20 degree weather down the interstate. I was in disbelief myself at first but I haven't seen much variation in it. I did have a low point in fuel efficiency for about 3 days once when I had a short that was only letting 4 of 8 cylinders detonate inwhich I could guzzle a quarter of a tank in 1 mile full throttle.
Car was bone stock and even now after some modifications done here in august I haven't seen much difference at all (hooker 2055 headers, no cat, hooker 3'' cat-back). Our big difference is the transmissions.
Old Oct 10, 2007 | 09:24 PM
DLV555's Avatar
Engine: 400 SBC
Axle/Gears: 4.10
Re: gas milage lo3
Okay, now I see. Your logic is a little flawed. Yes I have done well over 100 miles in a "quarter of a tank", but I have never come close to 400 miles in a tank. It is not because my fuel economy is that much better in the first half of my tank, but because the gauge is inaccurate. The gas gauge basically tells you a rough estimate of how much gas is left. You have to do your caluclation in full tanks of gas to have a more accurate estimation. Even then, that's all it is, an estimation. Fill your tank, reset your trip odometer, drive out the whole tank, refill and mark how many gallons you put in. Divide the miles on your trip odometer by the gallons on the pump and that is the best estimate of your average fuel economy. Otherwise I too get over 30 mpg, in the first half of my tank.
Old Oct 11, 2007 | 12:00 AM
Car: 91' Z28
Engine: 383 HSR
Axle/Gears: 4.11
Re: gas milage lo3
Yeah see your point on that, but never have actually ever had to drive full 400 miles on an interstate either. Thats like entire distance across my state . I've driven quite a ways on an interstate (~230), but then I end up driving in stop-go traffic quite a bit before/after so never had chance to do full tank comparison between the two. I might just have to do that sometime, spend entire day on the interstate....kinda hard with no scenery at all in this state about as boring as watching Nascar.
Old Oct 11, 2007 | 12:14 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: gas milage lo3
658.7 miles on 28.5 gallons was my best all highway mileage from my 305 TBI (1983 G20 Van). That was with 5 people, all the crap we had with us, running 70-75 MPH with the cruise set and the A/C blasting in the 100* Texas summer heat. Oh yeah, it was the stock 240K mile 305 converted to TBI (chip tuned by me) with long tube headers and 2 1/2" duals. 3.08 gears, 29" tall tires, and a 700r4 definately contributed.
Thats 23 MPG folks on a Van that has the aero of a FLYING BRICK
Old Oct 11, 2007 | 03:12 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: gas milage lo3
I always got around 22 mpg in the city +/- 3 mpg.
The L03 is done, though. Bring on the 350.
Old Oct 11, 2007 | 11:54 AM
DLV555's Avatar
Engine: 400 SBC
Axle/Gears: 4.10
Re: gas milage lo3
It only has to be all on the highway if you are focusing strickly on calculating highway miles. I just reset my trip odometer everytime I fill up and check my mileage right there at the pump everytime.
Old Oct 11, 2007 | 12:27 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: gas milage lo3
i get around 21 but i have a lead foot. I did a complete tune up and i go about 25-28 mpg on the highway using cruise. there is a stretch of highway though i go all the way to the speed govener and that couple of miles eat most of my gas.
Old Oct 11, 2007 | 12:34 PM
ryan91rs's Avatar
Transmission: 4L60
Re: gas milage lo3
Last edited by ryan91rs; Oct 11, 2007 at 12:35 PM. Reason: for some reason it posted twice, sorry guys
Old Oct 12, 2007 | 12:53 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: gas milage lo3
When I first came to school, which is about a 100 mile drive on the highway, I filled up right before leaving. I got to school, and the next day I was taking all my buddies for rides in the new car. I put about 55 miles on just ripping around back roads and burning out ect. When I filled up I expected to see like **** gas milage because I beat on the car for 50 miles. However, it averaged out to 28mpg. Considering the previous, then I proabaly got better than 30 on the highway. Around town I get 18-20 but that is my lead foot, and it is better when I dont stretch the gears out. The car has 52K on it and needs some sort of tune-up because it wont run in the rain.
On another note, anyone know how many gallons the tank is? I dont have an owners manual.
Old Oct 12, 2007 | 02:38 PM
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
Re: gas milage lo3
its either 14 or 15 IIRC.
Old Oct 12, 2007 | 04:09 PM
DLV555's Avatar
Engine: 400 SBC
Axle/Gears: 4.10
Re: gas milage lo3
It's likely more than 16 because I have put more than 14 gallons many times, and more than 15 I think as well.
92firebirdguy
Sep 1, 2016 07:53 AM
tonys91rs
Oct 10, 2015 03:31 PM
PestilenceIV
Sep 22, 2015 07:39 PM
anesthes
Sep 21, 2015 10:24 AM
64Chief
Sep 12, 2015 08:05 AM
