where is my map vaccuum?
Car: check
Engine: check
Transmission: check
Re: where is my map vaccuum?
The MAP line goes from the bottom fitting on the MAP sensor, to the fitting in the back of the TBI unit. This fitting is located between the fuel inlet/outlet's.
RBob.
RBob.
Car: check
Engine: check
Transmission: check
Typically the connection uses a piece of the skinny hard plastic vacuum line. As RF posted some 1/4" fuel line will work. It is a tad on the large side which will filter or lag the signal. But it works.
RBob.
RBob.
