TBI Spacers
Old Oct 17, 2007 | 08:35 PM
ems2357's Avatar
Car: 1989 Chevrolet Camaro "RS"
Engine: LO3 305 V8 TBI
TBI Spacers
Do they really work like they say gaining 20hp and like 40 lbs of torque?
Old Oct 17, 2007 | 10:04 PM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
Re: TBI Spacers
Chop the zeros off those numbers and I might believe it. Especially on a stock engine.
Old Oct 18, 2007 | 12:07 AM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Re: TBI Spacers
I dont know how much the numbers changed, but I could feel a difference on my LO3 when I put on the 1'' spacer. Is it snake oil? Not sure but I did notice a bit of a difference.
Old Oct 18, 2007 | 04:20 PM
ems2357's Avatar
Re: TBI Spacers
more power?...how did it act see i just want alittle more power....
Old Oct 18, 2007 | 04:48 PM
Car: 1991 Camaro RS
Engine: L98 350 TPI
Re: TBI Spacers
My throttle response seemed a little quicker and it felt like it launched a little harder off the line. When cruising and trying to accelerate, it did make it feel like it was lagging a little bit more. Like I said, though, I have no numerical evidence and I think that I heard somewhere that people have done testing and found no numbers difference...
I just know what I felt. I would do it again, even if it doesn't really do anything
The one that I had was a 1'', no name brand I bought off of Ebay, and it had the swirls cut into the sides of the holes. I had it installed in about 20 mins. It came with the longer TB bolts (make sure you get those).
The only draw back to it was that the wing nut for the air cleaner and the top of the air cleaner housing was in the hood insulation, so an open element, a taller air cleaner, or flipping the lid on the stock air cleaner housing may not work with the stock hood... I know that the wing nut on top of mine actually punched a hole in my hood insulation, and was a mere few mms from scraping on the underside of the hood itself.
Good luck
-Tim-
Old Oct 18, 2007 | 11:42 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: TBI Spacers
i had a 1/2"-3/4" spacer from my nitrous kit which used a plate. once i put it on it made absolutely no difference on my car unless nitrous was put through it
S10K20
Oct 7, 2015 06:45 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Glowsock
Sep 11, 2015 11:09 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
