Major Problems
Old Nov 9, 2007 | 12:49 AM
Pontiacguy18's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
Axle/Gears: 3.42 posi
Major Problems
The problems started about a month ago, I lost a lot of power from my 305 tbi 1991 firebird. I know there isnt a ton of speed to begin with, but not its running like a junkyard v6. I started by changing my fuel injector pressure regulator, then my map sensor, tps sensor, checked my timing, complete fluid flush, O2 sensor, and egr valve. Now I hear a ticking in my engine, and if I put my finger on the passenger side fuel injector (on top of it) the ticking is in time with the pulse coming from my fuel injector. I also am getting 10 miles to the gallon compared to my normal 17. Could this be as simple as a stuck fuel injector?
Old Nov 9, 2007 | 07:06 AM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
Re: Major Problems
chekc your plugs and wires. its very possible that one or two have fouled out.
Old Nov 9, 2007 | 12:29 PM
Engine: 305 TBI
Re: Major Problems
I did the plugs and wires, I went with the 8.5 mm msd wires and stock replcement plugs, dont remember the brand, bosch I believe. I also put in a blue streak cap and rotor.... still having the same problem
Old Nov 9, 2007 | 12:51 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: Major Problems
If you used Bosch plugs the next thing you need to do is take them out put in anything different. Then take the Bosch plugs to a shooting range and toss them as skeet. Bosch does not work very well in SBCs
It could be an injector problem.
AC Delco or Autolites are a good choice.
Verify your fuel pressure.
Old Nov 9, 2007 | 05:54 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Major Problems
Certainly verify fuel pressure. The BIGGEST problem that I ever have with TBI is loss of fuel pressure - for a variety of reasons. You need to buy the spring (for less than 5 bucks) that allows you to make your regulator adjustable. I like to get near 20 psi.
I always replace the fuel pump on every TBI application with a circa-1997 vortec 350 engine pump from a suburban. It gives you more flow than your stock system will ever need. I have put new TBI pumps in and had the same problem that you are having. Once I replace the pump and convert the regulator, those types of problems leave and never come back.
Hope this helps.
Old Nov 10, 2007 | 12:10 AM
Engine: 305 TBI
Re: Major Problems
I'm not sure if I did my fuel pressure regulator right... could it be as simple as that? also arent the fuel pumps in tank on these cars? how would I replace that
Old Nov 10, 2007 | 09:20 AM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Re: Major Problems
It absolutely could be as simple as that. You can buy the spring off of one of the advertisers here (can't remember which one) and if you search this forum for "spring" you'll find it.
You must pull your fuel tank to change the pump. That's why you want a good one and you won't have to do it again for a long time.
Old Nov 10, 2007 | 09:27 AM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Re: Major Problems
Check out this thread, it should help!
https://www.thirdgen.org/forums/tbi/...ng#post3234404
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
mrdevontay
Sep 2, 2015 08:04 PM
greenyone
Sep 2, 2015 03:39 PM
