intake manifold
Old Nov 30, 2007 | 12:22 AM
travishenry's Avatar
Car: 1988 Z28 Camaro
Engine: TPI 350
Transmission: TH350
Axle/Gears: 3.73 10 bolt
intake manifold
Does Edelbrock make the only TBI intake manifold. I cant find any others,
Old Nov 30, 2007 | 01:06 PM
Ronny's Avatar
Re: intake manifold
I believe GMPP makes one as does Holley. Actually almost any SB Chev manifold can be adapted to TBI with a plate.
Old Nov 30, 2007 | 03:39 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Re: intake manifold
Holley 300-66 I believe is the part number, I'm running it, it's a good intake. Do a search on here for intakes and you'll find a lot of options
Old Nov 30, 2007 | 03:50 PM
Ronny's Avatar
Re: intake manifold
Me too!
Old Nov 30, 2007 | 06:34 PM
Engine: TPI 350
Transmission: TH350
Re: intake manifold
ok cool i need to find a plate to adapt the tbi to a 4bbl intake then.
Old Nov 30, 2007 | 08:56 PM
90c350's Avatar
Re: intake manifold
Yes you can adapt any manifold to tbi You will just need to find an adapter plate. Holley makes one,Transdapt makes one and I think that you can get one from jegs as well. Do some searching there not to hard to find. I run an Edelbrock RPM-Airgap with TBI.
Old Dec 1, 2007 | 01:48 AM
Engine: TPI 350
Transmission: TH350
Re: intake manifold
Ok thanx a lot for the help. What do you think about a Victor JR.
Old Dec 1, 2007 | 02:16 AM
BronYrAur's Avatar
Engine: 305 TBI
Re: intake manifold
No idea what your setup is, so there's no way to say if that intake matches or not.
Old Dec 1, 2007 | 02:18 AM
Engine: TPI 350
Transmission: TH350
Re: intake manifold
Ok thanx for the help.
Old Dec 1, 2007 | 01:38 PM
90c350's Avatar
Re: intake manifold
Let us know what type of mods that you have done or plan on doing and it will help greatly in getting the right advice. I would recomend the victorjr unless you have done substantial work to the engine IE heads/cam/higher compresion/valve train etc. You would also loose a small amount of bottom end torque with that manifold and I would try a good dual plane intake for anything that is a daily driver. Just my thoughts though
Old Dec 2, 2007 | 02:51 AM
Engine: TPI 350
Transmission: TH350
Re: intake manifold
ok well tomorrow im taking my heads down to Rex Hutchinson to get them surfaced, full valve job on them. My valve guides are shot to no end. the motor hella smokes when i start it up. Im gonna be buying some headers from a guy on here some time in this next week. So ill have refreshened heads and some headers. So not sure where to go from there. i dont know if that victor jr will work or not. like you said ^ i prolly would loose torq.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Blue419
Sep 10, 2015 01:03 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
