TPS output motor cold
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
Re: TPS output motor cold
I'm going to say yes because the one I bought back in the spring/summer went out a few weeks ago causing the car to run like crap on a cold start and was throwing a high voltage code almost instantly.
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Computer always uses TPS output. And FYI closed loop only happens once the motor is warmed up. Open loop is for cold.
Are you having a problem? Or just curious?
Car: 92 Camaro RS
I have a definite problem. Engine has a very erratic idle when cold. Varies between 500 and 2000 rpm. The dirveabity of the car when cold is terrible. It moves a few feet about stalls goes a little further and does it again until it reaches about 45 and ten soothes out some. Idles and runs almost right when warm. I have replaced the fuel filter and EGR solenoid. Engine vacuum is a steady 17 lbs. Repair shop replaced the computer, IAC and colant temp sensor connector. They are at a loss of what to do now. I am tring to learn more to fix the problem
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Does the 'service engine soon' light come on?
Just taking a guess, my first thought would be the TPS (you can test it if you have a voltmeter to see if it has any dead spots) or just replace it, its about 8 bucks where I buy parts. My car did some very funky things similar to what you described when I had a bad TPS.
Let us know what you find!
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Try replacing the TPS just to rule it out. It's cheap and you can do it yourself in just a few minutes.
Are both injectors firing nice cones?
Does the SES light flash a few times when you first start the car to let you know it's alive?
Have you checked for vacuum leaks? You can try popping off various vacuum hoses and plugging the port to see if any of that fixes the issue.
Car: 92 Camaro RS
I was thinking about replacing the TPS.
Both injectors are firing a nice cone but looks like a lot of fuel.
The SES light does come on before starting to do the bulb check.
Engine tests 17" vacuum when idling warm.
Thanks for your ideas.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Car: 92 Camaro RS
The idle is a just little rough when fully warmed up. Power feels down a little when driving on the highway. I also noticed when driving on highway at 70 mph cruise was not keeping as steady speed as it used to. Would occasionally speed up to 72 and then slow to 68. May not be related.
The idle is a just little rough when fully warmed up. Power feels down a little when driving on the highway. I also noticed when driving on highway at 70 mph cruise was not keeping as steady speed as it used to....
mdtoren
Aug 16, 2015 05:45 PM
