Change the Pump
Old Dec 21, 2007 | 07:53 PM
kaupca's Avatar
Car: 92 Camaro RS
Change the Pump
Checked the fuel pump pressure on my 92 305 TBI engine today. Had 6 lbs pressure. Crimped off the return line and pressure did not change. Fuel filter is new. Engine idle speed went up and down as the fuel pressure changed from 6 to 4 to 6 pounds. Anything else to check before digging in to change pump?
Old Dec 21, 2007 | 10:01 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Change the Pump
You should check the auto parts store to see if there is a TPI pump in stock!
Seriously, you did what you needed to do; now change the pump.
Old Dec 21, 2007 | 10:44 PM
Jason89RS's Avatar
Re: Change the Pump
Or you could order a kit from autoperformanceengineering . I bought the Walbro 190 lph pump kit and have been very happy. I believe that the 190 lph pump will support something like 400 - 500 hp at 13psi
Old Dec 25, 2007 | 07:55 AM
tmorris71's Avatar
Car: 91 RS Convertible
Engine: 305 TBI
Transmission: 7004R
Axle/Gears: 2.73 - POSI
Re: Change the Pump
I am looking to buy the same pump. Did you need to order any extra parts from them or did the kit come with everything that you needed? I am thing of getting the extra fuel lines for internal tank use...not sure if they came with the kit. Also is this a good pump for a stock set up? Or is the pump going to be too much. I put in new injectors and rebuilt the fuel regulator (new spring and diaphram). Any advice is very help full.
Infested
May 22, 2018 11:56 PM
krisner89
Carburetors
Sep 20, 2015 08:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
