454 tbi problems
Old Jan 5, 2008 | 09:45 AM
Marksp's Avatar
Car: 1992 Z28 Conv.
Axle/Gears: 10 bolt, 2.73 posi
454 tbi problems
Hey guys my 1990 454ss is starting to **** me off. The truck runs like crap at part throttle and stutters an WOT. So far I've replaced the coil twice, dizzy, plugs, wires, knock sensor, and O2. And the problem is still there and seems to be getting worse. Anything else I should look at? I have a pressure gage and adapter on the way so I can check fuel pressure. Truck is all stock with the exception of no cat, and the timing is set at 6 deg btdc.
Mark
Old Jan 5, 2008 | 11:32 AM
Pre-Tuner's Avatar
Car: '91 Chevy 1500
Re: 454 tbi problems
Make sure the timing is what it's supposed to be, otherwise it throws off the timing in every table (unless you are custom tuning your chip).
Otherwise, deffinitely check the fuel pressure.
Old Jan 5, 2008 | 08:33 PM
oldred95's Avatar
Classic signs of a lean condition. Replace the fuel filter and go from there.
Old Jan 9, 2008 | 09:45 PM
Brandon2350's Avatar
Car: 1993 Z-71 pickup
Engine: Heavily modified 355 on TBI
Transmission: Had a 4L60e. Now a 700R4
Axle/Gears: Bone Stock
Get your FP guage and go from there. It could be a clogged filter or a failing pump.Once you hook your guage up you'll know.
Old Jan 13, 2008 | 08:11 AM
Marksp's Avatar
Car: 1992 Z28 Conv.
Truck only has 7 psi of fuel pressure. Not good huh?? Should be around 13 right? Where should I start the regulator or the pump? The filter is only a few months old.
Mark
Old Jan 13, 2008 | 10:32 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Perform a dead head test - pinch off the return line, while observing fuel pressure. If it zooms past 20 PSI FP is probably OK if it stays around 7 PSI, you have a tired FP, or fuel sock, or clogged in line filter or ruptured in tank hose.
//RF
Old Jan 13, 2008 | 10:34 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Regulators rarely fail by just loosing pressure. If they fail, which is rare, they rupture the diaphram and leak. Your pump is dead......
Old Jan 13, 2008 | 10:39 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Not necessarily, I have seen ALOT of springs fail by breaking into two.
MustangBeater20
Oct 29, 2022 09:20 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
