throttle bracket problems..
Old Jan 17, 2008 | 09:35 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
I have done a 350 swap into my 92 rs.I put an Edelbrock performer intake on it with a carb to tbi adapter plate..ok,now..I dont have anywhere to mount the throttle cable bracket that will give me the right travel on the cable.its either too tight(always open a little) or too loose(no WOT)..I need help..this is a simple fix I'm sure but I'm having a hard time with it....does anyone have pics of their install would you please post them if you do...thanks..Dave
Old Jan 18, 2008 | 09:48 AM
Ronny's Avatar
Re: throttle bracket problems..
consider a summit or edelbrock or lokar adjustable throttle cable bracket. after adjusted i ended up using a pop rivet to lock it in.
Old Jan 18, 2008 | 12:23 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The stock one will work provided you use adjustable throttle cable. I used the stock throttle cable housing but used a lokar adjustable cable for the internals. The other way is the adjustable bracket. I bought the edelbrock one, and it looked like it would work, but I never got to try it.
Old Jan 19, 2008 | 08:33 AM
dwillis's Avatar
Axle/Gears: 3:08
I got in touch with Lokar and they suggested using their universal cable and bracket so I will prob try that....Thanks guys
Old Jan 19, 2008 | 04:08 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
http://store.summitracing.com/partde...5&autoview=sku
i ended up using that bracket by edelbrock and it worked fine, the only problem is that it doesnt have a place for the cruise control cable but it was easy to adjust your throttle and tv cable properly.
here is the same one with a spot for cruise control
Old Jan 25, 2008 | 12:12 AM
dwillis's Avatar
Axle/Gears: 3:08
that may work for me because I have a t-5 and no cruise so I won't be needing that...I think Autozone carries that exact one..I may try it...Thanks man..
DiabloWS6
20
Dec 11, 2015 04:12 PM
L0tuS
Oct 4, 2015 08:07 AM
Hello, Michael
Sep 11, 2015 01:10 PM
TheTraut88
Sep 11, 2015 05:16 AM
Randomtask2
Sep 7, 2015 05:06 PM
