LT4 SPRINGS DO NOT FIT STOCK HEADS!!!!!!!!!!!!!!!!!
well after asking and reading, everone said lt4 springs fit, i orderd springs and retaners and locks all LT4 brand new from GM, they will fit the pockets that are flat but not the pockets that sonke in on the stock l03 heads, the O.D of the lt4s are bigger so now what? i dont want to take the heads off and have them milled this is basicly just pointless!
Car: 92 trans am clone
Engine: LO3
Re: LT4 SPRINGS DO NOT FIT STOCK HEADS!!!!!!!!!!!!!!!!!
itll be fine its just recommended to change them because of wear over years but you should be able to get away with it its like running an L98 cam.
Car: 1983 G20 Chevy
Transmission: 4L60
The LT4 Hotcam springs WILL NOT FIT, but the PRODUCTION LT4 springs should.
i tryed fitting the LT4 springs on a pair of stock 416 H.O heads i had laying around they will not fit the pockets that are snoke in, they fit the flat pcokets tho, the heads im putting the lt4s on are 187 heads thats in the car, heres some pics, what can i do? i have a few things i can think of doing
1) returen the springs and buy the springs listed in the LT1 cam thread
2) die grind the pockets bigger with a dimmon bit
3) not the best idea but shave some of the springs so they fit in the pockets
4) run stock springs
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
dont grind the spring!
if you do try to grind the spring pocket i can see a problem with you being consistant from pocket to pocket. your installed heights will vary. May not be a huge deal with stock like LT1/L98 cams but i just dont like that idea.
why not get comp 981 springs that are drop in replacements for stock valve springs? they are 1.25" diameter if not a tad smaller.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Ditto on the aftermarket springs. Cheap insurance. There are a variety of decent springs that can be made to work with the stock heads.
like these? these will work with a 94 LT1 cam with like 490 some lift ?
http://www.jegs.com/webapp/wcs/store...10002_33268_-1
do i now need new retainers? or can i reuse the ones i have agine this engine only has 60k miles thanks guys
Car: 89 Iroc-z
Transmission: TH400
thats the most popular drop in replacement spring for stock heads. will work good with LT1 cam but i dont know about the lift on stock heads. retainer to guide clearance becomes an issue at around .480 lift. So if you use 1.6 rockers, you may need to shim up the spring and run offset locks. the only offset locks i can find are 10 degree stuff, so you will need new retainers too. Thats roughly another 80 bucks for retainers/locks
Car: 89 Iroc-z
Transmission: TH400
with the price of springs being as cheap as they are, it be wise to get a fresh set.
theshackle
Mar 5, 2017 06:37 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
